URGENT HELP PLEASE - N47 Manifold removal
D155555
Post by D155555 » Sat Jan 13, 2018 11:23 am
Hi all
I am attempting to remove the manifold from my 123d - n47.
I have undone the 5 bolts on the manifold however the thing will not budge... not even the slightest.
Any ideas?
R5_RXK
Re: URGENT HELP PLEASE - N47 Manifold removal
Post by R5_RXK » Sat Jan 13, 2018 11:32 am
Hi all
Any ideas?
have you checked out the guide here mate:
viewtopic.php?t=84545
Owner of BMW E81 Sparkling Graphite M Sport 3 Door Hatchback
D155555
Post by D155555 » Sat Jan 13, 2018 11:34 am
Hi bud... yep I’m actually following that guide :-)
I’ve got all the way down to the 5 manifold bolts but now I’m stuck as the damn thing won’t move.
Do the glow plug connectors need to be removed?
Bimmer112
Post by Bimmer112 » Sat Jan 13, 2018 12:37 pm
I had the same problem with mine (although its M47). Used flat head screwdriver just to loosen it (put screwdriver in-between manifold and head, and twist it). After that everything went smooth. Hope this will help :)
BMW e87 118d M47N2
K+DCAN coding (NCS Expert , INPA ,Tool32...)
D155555
Post by D155555 » Sat Jan 13, 2018 1:02 pm
Power of force!
That’s budged it! It’s moving now....
Although not out... some thing is catching somewhere...
Greg.W
Post by Greg.W » Sat Jan 13, 2018 1:11 pm
Power of force!
Glad my guide has came in useful for someone! Lol
There are cables and pipes clipped to the underside of the manifold if I remember correctly. Try and squeeze your hand in and check.
D155555
Post by D155555 » Sat Jan 13, 2018 1:56 pm
Following it to the point mate... nearly there lol
https://youtu.be/nB4deMdDF5I
I’ve got the same issue as in the video above.... I cannot see anything else that requires unplugging.
