Manifold melted!
D155555
Manifold melted!
Post by D155555 » Sat Jan 13, 2018 6:24 pm
Quick low down
123d
2010
110k miles
Smoke started pouring out the manifold a few months back, AA recovered and it’s been parked up. I managed to strip it down to pop out the manifold. It has a hole in it, melted! (See attached pic). The swirl flaps all look intact.
So, question
What would have caused this? EGR ?
jason@bwchiptune
Re: Manifold melted!
Post by jason@bwchiptune » Sat Jan 13, 2018 10:02 pm
See this lot of times
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Dazbol
Post by Dazbol » Sat Jan 13, 2018 10:45 pm
Happened to mine mate, not sure what the cause was but if you buy a new one it'll set you back £650 for the part alone!
Recommend you try quarry motors if your near that way.
D155555
Post by D155555 » Sun Jan 14, 2018 1:08 am
Hi Jason, Any particular reasons for the failure?
D155555
Post by D155555 » Sun Jan 14, 2018 1:11 am
Great! Im in midlands , got a few bm scrap yards around here so will check with them first. Rather know what the root cause is ... don’t want it happening again.
Is your motor fine now? How longs it been since it was changed ?
jason@bwchiptune
Manifold melted!
Post by jason@bwchiptune » Sun Jan 14, 2018 2:37 am
Egr sticking open
That's why I set these to stay closed all the time in a remap
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW,Alpina Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal of its guts or replacement
40% of my work is repairing the problems that are caused by other tuners Remaps
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
D155555
Post by D155555 » Sun Jan 14, 2018 9:10 am
I had a feeling it may be something to do with the EGR.
So is it a case of removing and cleaning the EGR and refitting? Or does it need replacing once they are prone to stick?
jason@bwchiptune
Post by jason@bwchiptune » Sun Jan 14, 2018 11:10 am
The position sensor is probably not measuring were the valve position is
Remove the egr and check its movement to see if it's stuck open and clean it so it returns to closed position
Then have get the ecu software set so the egr is closed all the time (like closing and locking a door)
If you fit egr blanking bungs (it's like bricking a doorway up) you will still need to get the software codes in the ecu removed so why do it twice
Pick up a second intake manifold from a 120d or 123d and remove the swirl flaps,rod and rod bushes
Did you have any engine lights on the car before this problem happened?
BW chiptune
BW autorepairs
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Tez123d
Post by Tez123d » Fri Jan 26, 2018 2:59 pm
My 2008 123d has just been taken back to where I got it from its covered 93000 miles and they've just informed me the same has happened
Happy days
