E82 water pdc issues where does it come from?
Phil131
Post by Phil131 » Mon Jan 15, 2018 6:43 pm
Some of you may of seen my thread on the common issue I have had with water getting into where the pdc module is stored. Does anyone know where it comes in from? I have spotted condensation in my rear light but the amount of water in he bottom I wouldn’t of thought it would be due to that.
Jack79
Re: E82 water pdc issues where does it come from?
Post by Jack79 » Mon Jan 15, 2018 6:47 pm
It come from rear light seal. I used home window seal to be sure it will not come back. Sometimes rear vent are the issue
Nottsknots
Post by Nottsknots » Mon Jan 15, 2018 6:58 pm
Four likely candidates
1) the seal around the rear light cluster
2) the seal around the air exit vent (right next to the PDC module). The inner and outer parts are just clipped together, so if the plastic clips break/decay, then water can get past.
3) the vent itself; some were fitted upside down, so rather than letting air out whilst keeping water from getting in, the water just flows in
4) boot/hatch seal failure.
1 and 2 have been mentioned on here quite a bit. 3 is mentioned, but not as often. 4 is unlikely, but depends what you've had stuffed in the boot over years.
Mine was 2; sealed with some black roofing sealant (I used bitumin based, as it sticks like sh!t even in the wet, and remains flexible - some on here have used silicone). Mines been fine for a few years now.
Phil131
Post by Phil131 » Mon Jan 15, 2018 7:01 pm
Cheers guys will do some investigating thank you
jason@bwchiptune
Post by jason@bwchiptune » Mon Jan 15, 2018 8:48 pm
Boot vents under the rear bumper fitted the wrong way from factory lets water in to boot
New boot vent after we fitted them the correct way
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
