Do I have battery issues?
Bunford
Post by Bunford » Thu Jan 18, 2018 5:52 pm
I have a 2005 E87 118D Sport. I purchased the car in 2012 and it had one previous owner. Came with full service history and no mention of a battery change anywhere, so assuming it is still original battery.
However, I do get a couple of 'issues' recently, being:
1. Automatic headlight always auto goes to low beam, no matter whether it's day or night as if the daylight sensor is not working/off.
2. Automatic wipers always seems to wipe every 5 or so seconds, regardless of whether it's raining or not, or how heavy the rain is, as if the rain sensor is not working/off.
3. When locking and unlocking, all I hey is flashing indicators, but seem to think my sidelights use to come on too (but might be imagining that?).
4. My stereo will only come on when the key is in ignition and turns off as soon as key is popped out.
5. My dash cam, when set to turn off at 12.3v, only lasts about 20 minutes in parking mode before it turns itself off due to low battery.
The tip of the battery still shows a green indicator though, suggesting it is healthy. Also, how can I tell if it was the original battery?
I saw a way to check the voltage in another thread via a secret menu (viewtopic.php?f=11&t=106920#p1366573), which I plan on doing later this evening. Should I check with key in, engine off and sidelights on to discharge any static electricity in the system I take it?
I have also been checking for batteries and I think this one is compatible, but would welcome views: https://www.tayna.co.uk/110TE-Exide-Pre ... P7683.html
Re: Do I have battery issues?
Post by marco_polo » Thu Jan 18, 2018 6:06 pm
I'd be very surprised if it's the original battery, even if it is BMW branded?
Yes, check the voltage with the lights on to get rid of any surface charge, which can give erroneous readouts.
Bunford
Post by Bunford » Fri Jan 19, 2018 6:29 pm
Not got round to checking voltage, but when I went to my car at about 9.30am today the clock read 17:30, so the clock appears to have reset.
Is that another sign?
Nottsknots
Post by Nottsknots » Fri Jan 19, 2018 6:32 pm
Yep, the most common sign.
Bunford
Post by Bunford » Fri Jan 19, 2018 8:03 pm
Dang. I have looked at some of the car parts sites who use 'car detector' features to work out what battery, but I know these can be unreliable with batteries.
What are some good, solid, modern batteries in the realistically affordable price range?
