Hello from Spain with 118d e82 water temp? NEWS!!
victordaniels
Post by victordaniels » Tue Jan 23, 2018 9:05 am
good morning. First sorry for my English, I am Spanish.
I want to present my bmw, it's a 118d coupe year 2013
delighted to be here to learn with all of you.
   some photos
//uploads.tapatalk-cdn.com/201801 ... 3a77cf.jpg
//uploads.tapatalk-cdn.com/201801 ... 5d28ce.jpg
//uploads.tapatalk-cdn.com/201801 ... 4b1f0b.jpg
have a little problem
I am a little uninformed about this model and its temperatures.
I think the thermostat opens at 88 degrees and if I'm not mistaken the fan jumps to 97 ° (letting it warm up at idle)
I tell you my question. When I go on flat road gas tip 80-90kmh the car keeps stable between 91 and 94 °
At the moment I accelerate slightly or rogue in small steep climb to 96 or 97 stable ...
And if this same thing happens to me in a motorway in 6 ° to 123kmh of cruise, the temperature increases between 96 and 102 degrees. From there it does not happen.
It seems a little high to me. Since searching the entire network people talk between 91 and 93 or 94.
what can you owe those degrees of more?
The car heats up fast up to 90 °
I have looked at it in hidden menu and also by obd.
P.S. Buy the car and walked about 98- 102
But after removing the engine and changing the coolant when we made the chain, it was a little below.
Can I try changing thermostat or temperature sensor? Water Pump?
The car has 103,000km and is from 2013.
regards
victordaniels
Re: Hello from Spain with 118d e82 water temp?
Post by victordaniels » Wed Jan 24, 2018 8:46 am
from what I have read, these engines can work at different temperatures depending on the load.
Is it like that?
Thank you
YLS
Post by YLS » Wed Jan 24, 2018 2:31 pm
Have you removed all of the air from the coolant? (Bleeding the coolant).
victordaniels
Post by victordaniels » Wed Jan 24, 2018 5:38 pm
Hi.
thanks for answering.
the work was done by a mechanic.
You explain how I can check if it's okay?
How to bleed the system?
Thank you
Post by marco_polo » Wed Jan 24, 2018 7:32 pm
If the car is trying to clean / regenerate the exhaust Diesel Particulate Filter, it will run hotter than the usual 88°C due to the extra fuel being burned.
Ezzra
Post by Ezzra » Wed Jan 24, 2018 7:43 pm
Your English is excellent :D
What part of Spain are you from?
victordaniels
Post by victordaniels » Wed Jan 24, 2018 7:53 pm
Hi.
the dpf is fine because when it is regenerating I have seen that the temperature goes up.
the problem is always
when I look at obd torque or hidden menu it is never below 91 or 92 degrees without accelerating.
the coolant level is fine.
Thank you very much for the help
victordaniels
Post by victordaniels » Wed Jan 24, 2018 7:59 pm
Thank you jaja.
I'm from asturias in the north.
in Spain, there is not much talk about bmw 1 series
and I found this forum by internet.
Thank you very much for the welcome.
It's a pleasure to meet people like all of you
Ezzra
Post by Ezzra » Wed Jan 24, 2018 9:39 pm
Thank you jaja.
I love Spain. Hoping to move to southern Spain (Denia) in the next few years :)
victordaniels
Re: Hello from Spain with 118d e82 water temp? NEWS!!
Post by victordaniels » Thu Jan 25, 2018 4:53 pm
I have been able to verify that if I drive at 120km / h in 5th gear instead of in 6th gear the temperature if it stays between 89-91 degrees
Water Pump?
Thank you
0l0dom0l0
Post by 0l0dom0l0 » Thu Jan 25, 2018 4:55 pm
It's fine there's nothing wrong with it.
B12 KIT with M3 LCA and TS.
victordaniels
Post by victordaniels » Thu Jan 25, 2018 4:58 pm
Do you think that a temperature of 96-100º driving at 1800rpm is normal?
Then can my car be okay?
Thank you
0l0dom0l0
Post by 0l0dom0l0 » Thu Jan 25, 2018 6:52 pm
Thank you
Yes that's normal.
Temperature will fluctuate depending on driving conditions and airflow etc.
If it goes over 115 you should worry.
YLS
Post by YLS » Fri Jan 26, 2018 9:19 am
Yes that's normal.
Really? Mine varies, but only perhaps 2 or 3 degrees above and below 88. New main and EGR thermostat in the last few months. Hard to know what 'normal' is when I've only got one reference point. I thought mine was normal!
victordaniels, what is the outside air temperature where you are driving?
Can you try something? Drive at 1800rpm in 6th gear. Will this make the temperature go to 96-100 C? While still going at the same speed, push the clutch pedal down and rev the engine to 3000-4000rpm for 4 or 5 seconds, then carry on driving as normal. Does the temperature rapidly drop?
0l0dom0l0
Post by 0l0dom0l0 » Fri Jan 26, 2018 10:07 am
Yes that's normal.
Some movement in coolant temp is normal.
At this time of year, the stat will hardly be open and will have lots of headroom to open more and increase coolant flow through the radiator as you have a very large detla between the water and ambient air so less water flow is required through the rad to remove the same amount of heat - hence good temperature control.
Once the stat is fully open, the difference in temperature between the coolant and ambient air going over the radiator and amount of going over the radiator is what dictates the amount of heat that can be taken out of the coolant to keep the car cool, coolant flow is maxed out.
Therefore the temperature of the coolant rises until either the airflow or the delta t between coolant and ambient air is great enough that the same amount of heat can be removed as the engine is adding.
When the car reaches a certain temperature and neither the delta t or the flow of air is sufficient to remove the amount of heat the engine is adding, the cooling fan switches on, and increases airflow.
Tldr: Movement in coolant temperature is normal. It should however, once warm, not drop below the temperature the stat is controlling to.
