Gear Changing
RLacey
Gear Changing
Post by RLacey » Thu May 17, 2018 11:44 am
Hello,
I have a slight issue which is bugging me, sometimes when im sitting in traffic its really hard to put in 1st gear (sometimes makes sort of a crunch sound) and also 1st to 2nd is not smooth at all making sort of a crunch sound to and then the higher gears are fine i think.
Double clutching 1st to 2nd gets rid of the noise and if i delay the change to about a second its fine, clutch delay valve?
Had my clutch, flywheel and oil changed so any info would be appreciated.
2008 135i e82
Re: Gear Changing
Post by marco_polo » Thu May 17, 2018 11:47 am
If your clutch is new, and the clutch lines correctly bled (?), your 1st - 2nd synchro has probably worn out.
YLS
Re: Gear Changing
Post by YLS » Thu May 17, 2018 11:52 am
Was it like that before the clutch change?
Assuming this is a new problem, I'd take it back to the garage and get them to investigate it. If you want to DIY, I'd check it's 100% properly bled first.
RLacey
Re: Gear Changing
Post by RLacey » Thu May 17, 2018 11:56 am
Yes it was like that before all the changes guys, thanks
YLS
Re: Gear Changing
Post by YLS » Thu May 17, 2018 12:13 pm
For the cost/time it would be worth removing the CDV and re-bleeding, just to rule it out. Worth a shot...
RLacey
Re: Gear Changing
Post by RLacey » Thu May 17, 2018 12:56 pm
Yeah i will try that and report back, Thanks
Rarebit
Re: Gear Changing
Post by Rarebit » Thu May 17, 2018 1:40 pm
Same as my 130i. Try turning the whith bush the gear stick sits in (fulcrum - under the gaitor)..also add some lube to it.
130i LE
