Changed rear lights , now getting bulb alert
leeballleeball
Post by leeballleeball » Sat May 19, 2018 9:12 am
Morning all
Literally just changed my rear lights from standard to these
https://www.energizedcustoms.co.uk/shop ... mpaign=map
Now then I start the car I’m getting an alert on the dash
All I had to change was the reversing light. So I’m thinking as the other lights are led the car may think the bulbs are dead
Is there a work around for this or is it either put up with the noise or jsut get rid
Appreciate any help, thanks
Nottsknots
Re: Changed rear lights , now getting bulb alert
Post by Nottsknots » Sun May 20, 2018 9:09 am
....the other lights are led the car may think the bulbs are dead
You got it yourself :)
You need to code out the bulb check: I think you can do it if you use Carly, or you could PM Wibbles on here and he can do it remotely (for a fee :D ).
http://www.babybmw.net/viewforum.php?f=95
