123d dynoing at 177bhp
ben123d
Post by ben123d » Thu Jun 21, 2018 8:11 pm
Following a run on the dyno, my 123d is said to be running at 177bhp, which is quite a step down from the stock horse power.
Other than the dyno not being completely accurate (albeit it can’t be that bad!), what might be causing a lack of power?
The dpf was read reading low, so it’s not blocked.
Service the car every 12 months and do less than 10,000 Miles a year.
My thinking is to start replacing some hoses if I’m loosing boost through perished piping or possibly the accuator (s) are sticking? EGR valve blocked and thus engine isn’t breathing properly. Not noticed any flat spots whilst accelerating in low or high gears.
Any info or advice would be highly appreciated.
Ben
Ezzra
Re: 123d dynoing at 177bhp
Post by Ezzra » Thu Jun 21, 2018 8:42 pm
Sounds about right Ben. They only made a couple of hundred horsepower at the crank when new :)
stevesurrey
Post by stevesurrey » Thu Jun 21, 2018 9:59 pm
How old is she and how many miles on the clock ?
jason@bwchiptune
Post by jason@bwchiptune » Thu Jun 21, 2018 10:48 pm
I've had many of these only making 184bhp as standard
Can you post the dyno graphs
Does the car pull from the start or only from 2300rpm
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Tez123d
Post by Tez123d » Fri Jun 22, 2018 11:36 am
I had a similar problem but mine was only doing 141BHP
EGR valve has failed and someone had put a blanking plate in the cooler .
Hope to have some updated news soon
BMW E81 123D M-Sport 2007
ben123d
Post by ben123d » Fri Jun 22, 2018 7:08 pm
Car is a 2008 plate with 101,000 Miles on the clock.
The car feels like it pulls all the way through the Rev range.
I didn’t get the graphs at the time but have chased him up for them and hopefully will get them soon.
ben123d
Post by ben123d » Fri Jun 22, 2018 7:09 pm
141 bhp is pretty bad!
Have you put an EGR valve back on? Or had the engine cleaned out?
Tez123d
Post by Tez123d » Sun Jun 24, 2018 11:24 am
New egr valve and cooler has been installed just waiting for next dyno slot
jason@bwchiptune
Post by jason@bwchiptune » Sun Jun 24, 2018 11:46 am
Tez123d wrote:I had a similar problem but mine was only doing 141BHP
If someone had fitted a blanking bungs and no lights or codes have come up then they would of removed codes for the egr
The problem is when the person doing it doesn't know where each code address are so they then turn off all or more codes than needed
This then causes other problems when people are just looking at codes when a engine has issues
If anyone wants to remove the egr I always recommend to set the egr to stay closed all the time in the engine control unit then there is no need to turn off any codes, the dpf will still regen as normal instead of fitting blanks which can then cause more problems when someone then turns off all the codes as ive seen this loads of times
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
ben123d
Post by ben123d » Mon Jun 25, 2018 4:22 pm
Does it feel any better with the new EGR and cooler?
Tez123d
Post by Tez123d » Mon Jun 25, 2018 7:56 pm
Pick car up toady and it feels a little mental
Custom map all sorted with all of its new bits on its a totally different car now
Low down grunt seems the same but just revs faster and goes mental over 2000 just seems to rev now without any issues
ben123d
Post by ben123d » Tue Jun 26, 2018 11:26 am
That’s great to hear. Always nice to get to the bottom of something and get it sorted!
Did you find out what the problem was? Was it just down to replacing the EGR or was their some codes needing turning back on / off?
Most importantly, what’s it now putting out on the dyno?!
Ben
Tez123d
Post by Tez123d » Tue Jun 26, 2018 12:06 pm
Not Sure on power yet as didn't pick the graph up im off back there in 2 weeks for MOT
From What i can gather it was a very poor map originally on the car , then when the map was tweaked it showed the issues the car had with the blanking plate in the EGR cooler .
now with the new cooler on and valve and mapped to suit the conditions its night and day difference
ben123d
Post by ben123d » Tue Jun 26, 2018 12:55 pm
It’ll be great to see the before and after maps. Out of interest, where did you go for the work?
Could also ask where you got the new EGR valve and cooler?
Tez123d
Post by Tez123d » Tue Jun 26, 2018 2:20 pm
I used a company called PK Automotive here in Lincoln
BW chiptune was my first port of call but its the distance to Jason that i couldn't do if only he was closer but with his knowledge and experience i should have just gone to him
