123d dynoing at 177bhp
ben123d
Re: 123d dynoing at 177bhp
Post by ben123d » Tue Jun 26, 2018 2:24 pm
Tez123d wrote:
Tue Jun 26, 2018 2:20 pm
I used a company called PK Automotive here in Lincoln
BW chiptune was my first port of call but its the distance to Jason that i couldn't do if only he was closer but with his knowledge and experience i should have just gone to him
Where did you purchase the new EGR valve and cooler?
Tez123d
Post by Tez123d » Tue Jun 26, 2018 3:17 pm
it was through halfords as the car has its own warranty attached to it .
The Parts as far as i know are genuine BMW parts
BMW E81 123D M-Sport 2007
ben123d
Post by ben123d » Tue Jun 26, 2018 6:45 pm
I wonder if you would have the same results if you just got the coding done properly without reinstalling a new EGR and cooler?
Those coolers ain’t cheap!
jason@bwchiptune
Post by jason@bwchiptune » Wed Jun 27, 2018 3:36 am
ben123d wrote:I wonder if you would have the same results if you just got the coding done properly without reinstalling a new EGR and cooler?
If the egr was programmed out correctly then there would be no needed to fit a new one
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Tez123d
Post by Tez123d » Wed Jun 27, 2018 7:08 am
This is the problem Jason under further inspection this car has been mapped really badly in the past, dpf seems to have been mapped out too.
But thankfully its going well now
jason@bwchiptune
Post by jason@bwchiptune » Thu Jul 05, 2018 7:45 am
Have you had the remap corrected yet as I've seen loads like this
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Tez123d
Post by Tez123d » Thu Jul 05, 2018 8:53 pm
Car has been mapped again and there are no errors on the dash, seems to pull like a train and is very revvy now.
Feels like a petrol.
Not had any figures yet as I'll be popping back on Saturday for my mot and I'll ask then for the dyno print out.
Only thing I'm having replaced now is the mass air sensor as apparently it needs one
Oh and glow plug number 3 still needs changing but that can wait as I'll have to pay
ben123d
Post by ben123d » Fri Jul 20, 2018 10:32 am
Thu Jun 21, 2018 10:48 pm
I've had many of these only making 184bhp as standard
Can you post the dyno graphs
Does the car pull from the start or only from 2300rpm
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
Eventually got the map. Apologies for the rubbish photo.
Car seems to pull from the start, but I’m sure the graph will tell you more.
jason@bwchiptune
Post by jason@bwchiptune » Sat Jul 21, 2018 10:12 pm
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
Is this dyno graph before or after it's been fixed as a standard car as it's only made 180bhp at the flywheel/engine ?
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
ben123d
Post by ben123d » Sat Jul 21, 2018 10:47 pm
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
This is how it was run on the dyno when I brought it in to him.
Didn’t have a map done or any repairs, because it was running 20+bhp below stock.
Thought it best to try to find out why it’s running low rather than just sticking a map on.
Does the map give any clues to why it’s running low bhp?
jason@bwchiptune
Post by jason@bwchiptune » Sun Jul 22, 2018 7:35 am
There seems to be a dip in power from 2200-3000rpm this would cause the top end power top drop some
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
ben123d
Post by ben123d » Sun Jul 22, 2018 6:07 pm
You think that might be an issue with the actuators where the big turbo is coming in? Either sticking or not fully opening?
jason@bwchiptune
Post by jason@bwchiptune » Sun Jul 22, 2018 6:51 pm
Looks more lower down the rev range
I would need to do tests on my dyno to look at it to tell
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
