Brake upgrade
CharlieEdwin
Brake upgrade
Post by CharlieEdwin » Sun Jul 08, 2018 10:38 pm
I'm thinking about upgrading the brakes on my e87 120d. Are the brakes from the 135i worth it? Or shall I just put in a EBC brake disc and pad upgrade kit?
Or any other brake upgrades people recommend?
120d sport e87: Bilstein b12 pro kit, straight pipe turbo back exhaust, bola wheels, strut brace, some powerflex bushes, alcantara and flat bottom steering wheel, remap by BW chiptune, interior mods, duck lip spoiler, more to come 👌
fmn716
Re: Brake upgrade
Post by fmn716 » Sun Jul 08, 2018 10:41 pm
335i brakes have my vote straight easy swap. A good upgrade for non 135i cars. And discs and pads are cheap
HaiderGill
Re: Brake upgrade
Post by HaiderGill » Mon Jul 09, 2018 9:12 pm
You could get a set of M Performance (blue) or the BMW Performance (golden yellow) brakes for the fronts. The blue 4 potters are meant to be better...
o..
Re: Brake upgrade
Post by o.. » Mon Jul 09, 2018 11:27 pm
Cool, so what’s needed for that 335 brake upgrade? Discs, pads, callipers and carriers? Anything else?
Also, do both 335i and 335d brakes fit and how much bigger / better are they than a standard 123d?
Cheers for the assistance, this looks like a great mod.
o :)
CharlieEdwin
Re: Brake upgrade
Post by CharlieEdwin » Mon Jul 23, 2018 8:45 pm
With the 335i calipers they run a 348mm disc. I assume this will fit fine with my 18" wheels? And as previous asked what's need to secure these?
fmn716
Re: Brake upgrade
Post by fmn716 » Mon Jul 23, 2018 10:26 pm
fmn716 wrote:335i brakes have my vote straight easy swap. A good upgrade for non 135i cars. And discs and pads are cheap
These are 335i calipers with 335i rotors (348mm) with 18” wheels. They just fit
baderlfc
Re: Brake upgrade
Post by baderlfc » Tue Jul 24, 2018 3:52 pm
Slightly off topic but relating to brakes... Does the E82 135i have the kevlar reinforced brake hoses like on the F series X35/X40's?
If they don't then braided hoses could be a good addition to your upgrade plan.
fmn716
Re: Brake upgrade
Post by fmn716 » Tue Jul 24, 2018 4:18 pm
I had Goodrich steel braided lines in my civic and the pedal was hard. I do prefer not having them as it’s nicer for a daily in my opinion but each to their own
R99
Re: Brake upgrade
Post by R99 » Tue Jul 24, 2018 6:44 pm
Fit F3x 340mm front brakes - the 4 pot Brembo's.
2016 F31 330d M Sport Touring
Individual Pure Blue | Oyster Leather | M3 Mirrors | MP Kidney Grilles | ID6 | Custom Steering Wheel |
fmn716
Re: Brake upgrade
Post by fmn716 » Tue Jul 24, 2018 9:11 pm
R99 wrote:Fit F3x 340mm front brakes - the 4 pot Brembo's.
I agree if u have the money spend it on these and not the 6pot. For budget get the 335i calipers
reidtastic
Re: Brake upgrade
Post by reidtastic » Fri Jul 27, 2018 9:30 pm
Hi guys,
Pretty interested in this upgrade for my e82 125i
Can someone answer the following ?
Is this a straight swap eg original lines used ?
Do these fit under 18” 261 without spacers ?
fmn716
Re: Brake upgrade
Post by fmn716 » Fri Jul 27, 2018 10:13 pm
reidtastic wrote:Hi guys,
I used the brake hoses that were on the car which were e87 120i. You just need 335i front calipers and brackets. I have not installed the 335i rear brakes
reidtastic
Re: Brake upgrade
Post by reidtastic » Fri Jul 27, 2018 10:23 pm
Perfect, it’s just the fronts I’ll be doing - is the pedal feel the same ?
Also what’s the clearance like on the on the wheel face and inner diameter estimate in “mm”
reidtastic
Re: Brake upgrade
Post by reidtastic » Fri Jul 27, 2018 10:32 pm
Also did you fit the 335i splash / dust shields ?
fmn716
Re: Brake upgrade
Post by fmn716 » Fri Jul 27, 2018 10:55 pm
I am still using the stock 120i dust plates but I plan on upgrading that soon. I will try find the post where I posted pics of the caliper-rim spacing. Pedal feel is exactly the same. For the size of the calipers they are really light only difference you will notice is breaking distance will decrease. If you had to go with steel braided lines the pedal feel will be hard. Hope that helps. I will take pics of how the 120i dust cover looks with these rotors
