Single Din to Double Din Head unit
marcusoxon
Post by marcusoxon » Mon Jul 16, 2018 1:52 pm
Hi,
I have the fascia for a single din head unit. I want to move to a double din unit. Does anyone know the part number for the double din version of the function carrier center?
Thanks in advance
LanceG
Re: Single Din to Double Din Head unit
Post by LanceG » Mon Oct 08, 2018 4:48 pm
pujajoshi wrote:Single din head units can only be replaced with other single din head unit. If your car came with a double din stereo then you have some more options.
Not 100% accurate
Pre face lift requires new upper and lower dash to house a double din.
It's been done a few times on here
If you have the lci model you can grab a fascia from dynamic sounds or similar and your sorted.
Sent from my LG-H850 using Tapatalk
120d Pre facelift SE - Double Din | M Sport Suspension | eibach pro lowering springs | Swirl Flaps Removed
TO DO: Rims | Remap
