xenon regulator rod.
rm1
Post by rm1 » Tue Aug 14, 2018 10:12 am
Hi I am about to install m3lcas on my 2006 130i can someone confirm that this is the right part number for the xenon regulator rod that's needed when you switch to m3 arms part no: BMW
37142283867
thanks in advance.
Re: xenon regulator rod.
Post by THETYRANT » Tue Aug 14, 2018 10:48 am
Thats the one, before you start make sure your track rod ends are not seized which is a common problem, if you swap the LCA and then find you cant adjust tracking via tie rods then car is undrivable really.
andrewuk1990
Post by andrewuk1990 » Tue Aug 14, 2018 11:00 am
Definitely second this one! I had a tough time getting mine loose way back when I changed these. A few consecutive days of penetrating oil, wire brushing and a few knocks with a hammer suddenly got mine moving. I completely unthreaded them and copper greased before refitting and aligning. Never had a problem since when it's gone for alignment adjustments so would recommend that if they give you grief.
BMW 123d E82 - 290bhp, 600Nm @ 2.4Bar
Bosch CP4.2 Fuel Pump, FTP Charge Pipes, Mertop Racing Intercooler, Darkside DPF, M3 Wishbones, TYRANT Stage 2 camber plates, BMWP Calipers w/ EBC Y & Strongflex Subframe Poly Bushes, Bilstein B12 Pro Kit, MPS4
rm1
Post by rm1 » Tue Aug 14, 2018 11:03 am
Thanks guys.
