Will the 335i brake set up bolt on my 118d (E81) ?
Jingle
Post by Jingle » Thu Feb 07, 2019 1:22 pm
Hi all, I need some new discs pretty soon on my 2009 E81 118D.
I want to get some bigger discs so have been looking into using the 335i brake set up if it’s a straight bolt on?
I’m pretty sure the front 348mm discs (and callipers) from the 335i will bolt straight on and work.
Does anybody know if the rear 336mm discs (and callipers) from the 335i will fit? If not, what’s the best alternative?
Thanks!
Jingle
Re: Will the 335i brake set up bolt on my 118d (E81) ?
Post by Jingle » Sun Feb 10, 2019 7:14 pm
Guessing nobody has done it?
From what I’ve read the fronts are fine, should I just get the 120d set up for the rear, not a massive step up, but will at least use a 300mm disc
pb5
Post by pb5 » Sun Feb 10, 2019 8:20 pm
Hi
I've not done it but I think you have make sure your wheels are big enough to clear them.
Paul
Toed64
Post by Toed64 » Tue Feb 12, 2019 1:15 am
There are a couple of threads you should read to learn all you need to know.
https://www.babybmw.net/viewtopic.php?f=20&t=84300
viewtopic.php?f=20&t=110972
The 335i single pot, floating caliper will fit the front of your car, but it's quite a hefty thing. Most are fitting the F series (M135i etc) Brembo calipers and discs, consequently, you might find a forum member selling a pair of 130i front calipers and discs, that would be a nice upgrade over the ones fitted to your car.
Now in a 2008 E81 130i, previously 5 years in a 2010 E82 135i.
Jingle
Post by Jingle » Wed Feb 13, 2019 9:55 pm
Thanks for the replies guys. Lots of reading and research has lead me to just get the 335 front callipers and 348mm discs/pads and just the 118d/120d rears for ease.
I do love the look of themose blue F series M callipers!! Hefty price tags, but they certainly look the part!!
Wish me luck!!
