135i exhaust onto 130i
Fritz
Re: 135i exhaust onto 130i
Post by Fritz » Fri Dec 29, 2017 1:39 pm
Twenny wrote:
Fri Dec 29, 2017 1:34 pm
Fritz wrote:Guys apart from changing the hangers does the 135i backbox need much working to fix it to the 130i standard mid? Will it make much difference to the sound on it's own?
The 135i backbox pipe is bigger than the 130 exhaust pipe so will need some decent welding to make it fit perfect.
And yes it’ll make a nice deep grumble and no drone.
I see, so I assume most people have the 130i mid mated up to the 135i bbox by an exhaust place. Do you happen to know the difference in pipe diameter?
Post by Twenny » Fri Dec 29, 2017 1:49 pm
Sadly not no, sorry. But this was my thread below before I got the 135i performance backbox added a while later which made an even better sound -
http://babybmw.net/forum/viewtopic.php?t=64231
Fritz
Post by Fritz » Fri Dec 29, 2017 2:04 pm
Cheers Twenny!
Post by Twenny » Fri Dec 29, 2017 2:25 pm
Cheers Twenny!
Can’t upload videos to this forum anymore which is annoying.
Here’s a cold start - https://youtu.be/T3tKNA8Sxwk
If you search my YT channel there’s a few vids I’ve just added
Fritz
Post by Fritz » Fri Dec 29, 2017 4:34 pm
Does sound great, thanks for uploading these. Were they all with these with the resonator delete too?
This sounds brilliant:
https://www.youtube.com/watch?v=CAm66QFMT6w
Post by Twenny » Fri Dec 29, 2017 7:04 pm
Fritz wrote:Does sound great, thanks for uploading these. Were they all with these with the resonator delete too?
All I’ve done is add a standard 135i backbox and then later a 135i performance backbox, no resonator delete as wasn’t sure of drone. I’m tempted but happy with what I have so o think I’ll leave it as is.
I believe OoDomoO has had the BMWP 130i backbox and res delete and I’m pretty sure he’s very happy with the results.
Fritz
Post by Fritz » Fri Dec 29, 2017 9:14 pm
Sounds good enough as it is to me. I don't really want it to drone, I drive back and forth to Germany every few months and that could be a right pain in the backside. My old S14a had a big old fart can on it and whilst it was great fun it did become tedious, wouldn't want to have something like that on a daily.
In this vid it sounds really good considering it is just the backbox: https://www.youtube.com/watch?v=CAm66QFMT6w
wil
Post by wil » Wed Jan 10, 2018 2:02 pm
I finally got this done. It is awesome! Custom Y pipe made up to replace mid section and standard 135i backbox modded to fit by local company.
No drone, subtle at low revs and raspy and loud under load, and poppy and burbly on overrun
couldn't be happier.
Black 130i
Jack@AUTOID
Post by Jack@AUTOID » Wed Jan 10, 2018 4:31 pm
I've had the Y pipe done but still on the 130i exhaust. On the look out for a 135i backbox now.
AUTOID
autoid.uk.com
jack@autoid.uk.com
‭020 7205 2429‬
E81 130i LE
BMWP Short shift kit, Handbrake, Front Bumper, Grilles, Side skirts. 15mm spacers all round. Cruise Control Retrofit. Res delete, 135i BMWP Back Box + few more bits.
supercati
Post by supercati » Wed Jan 10, 2018 8:29 pm
Well done mate! :D
I think it's the best setup :) I can't thank enough holland130i for the idea.
If you are around 3000rpm and you release throttle, you will have nice "burble", or while you are around 3000rpm and just pressing veeeery gently the throttle like small pulsations, you will get also that "pop and crackles" :mrgreen: :mrgreen: :mrgreen:.
And then, just this you mention: quiet at low rpm, and 6L BMW great sound when you apply good throttle or you're in high revs.
130i E81 2007 LHD - Sparkling Graphite Metallic / Boston Terra - CDV Delete - 135i ESD with resonator delete - LED Blacklines - RIP :(
130i E81 2008 LHD - LSE / Boston Terra - Complete HiFi Retrofit - CDV Delete - LED Blacklines - BMWP SSK -
holland130i
Post by holland130i » Thu Jan 11, 2018 8:07 am
Great isnt it?... well done mate!!
:-D
Mark.
holland130i
Post by holland130i » Thu Jan 11, 2018 8:08 am
Well done mate! :D
My pleasure!
:headbanger:
Mark.
walkie86
Post by walkie86 » Tue Jan 16, 2018 4:53 am
Stock rear muffler off an N55 135i on my 130i - no golf tee mod. Note, my online researchs suggests the N54 and N55 mufflers are different inside the back box.
Cold start up:
https://youtu.be/-9eSFM4fRQA
Le Mans Blue '06 E87 130i 6MT (almost fully optioned) - 135i muffler:ZHP knob:AC Schnitzer Type3 18x8.5:Nolathane rear subframe bushes:camber pin mod:E9x M3 front sway/LCA:CF front splitters:Aero spoiler:LCI Darklines
Poormans
Post by Poormans » Tue Jan 16, 2018 10:00 pm
Looks like the cold start opens up the valve, so ought to sound like a golf t mod?
shooting brake
supercati
Post by supercati » Tue Jan 16, 2018 10:50 pm
That's correct.
N55 mufflers sound a little bit better :)
