Throttle closures with mhd stage2+
Speedychuck
Post by Speedychuck » Mon Apr 17, 2017 8:00 pm
Now my clutch is bedded in I've finally been able to log a pull on mhd stage 2+.
Looks like I'm getting some overboost causing some throttle closures as I boost up. Previously with mhd maps the boost runs slightly below target but this seems slightly over. Do any of you have any ideas what's causing it? Or is it that the car will adapt over time?
I realise not many of us on here run mhd, but I thought I'd ask anyway in case any lurkers can help me out.
See log here
http://www.datazap.me/u/speedychuck/sta ... 1&mark=107
Thanks!
'09 AW N54 135i - CIC - Logic 7 HiFi - MHD Stage2+ 98 - Wagner Evo 1 Performance I/C - VRSF Intakes - STC downpipes - 550i Clutch - BMWP Mirrors / Diffuser / Grilles / Skirts / Y-Pipe - SSDD Spoiler
12.9sec 1/4 mile @ 112mph - Santa Pod
AdamHarbour
Re: Throttle closures with mhd stage2+
Post by AdamHarbour » Mon Apr 17, 2017 8:13 pm
I updated my jb4 firmware after installing my inlets a few weeks back which was causing massive over boost but eventually the car adapted and has been fine since so that might be the case here.
N54 135i | JB4 | VRSF FMIC | VRSF down pipes | N55 mids | BMS charge pipe + BOV | Stage 1 LPFP | BMS meth kit | Carbon bonnet | Reiger diffuser | Darklines | MHD race flash | spec stage 3+ Clutch | MMP Inlets | 470hp-560ftlbs | 12.7@115mph 1/4 mile |
Sam_M
Post by Sam_M » Tue Apr 18, 2017 3:40 pm
Have you asked on the MHD megathread on 1addicts?
2011 E82 135i - 6MT - Sunroof - Harmon Kardon - ProNav - Xenons
Speedychuck
Post by Speedychuck » Tue Apr 18, 2017 7:26 pm
I posted it elsewhere on e90post maybe I should try that thread also. Thanks for the link.
Adam- hopefully you are right and it will adapt eventually although if I'm brutally honest, it doesn't really seem to be affecting the way the car pulls.
Sam_M
Post by Sam_M » Wed Apr 19, 2017 9:36 am
No worries, the guys who make MHD are really active on that thread. :)
Have you tried resetting the throttle adaptation in MHD? Might be worth a go if not.
Bluebird
Post by Bluebird » Sat Aug 18, 2018 5:32 pm
Sorry to thread revive but I'm having this issue with mine. Did you sort it?
M135i | Estoril Blue | ZF8 | MHD2+ - ~400bhp/630NM
Dizzy619
Post by Dizzy619 » Sun Aug 19, 2018 10:44 am
Hi mate... I had problems recently of a different nature... In the end I emailed MHD direct.. They were pretty helpful..
Probably worth a try.
Also log a wot run in 3rd and post it on the relevant sites.
Darren
57 plate sedona red 135i. Quaiffe diff 1M suspension bits, afe induction kit, forge fmic, mhd maps, bilstein b12.. :lol:
