Hard cold start, Shaky idle and stop/start
Find out more about the BMW 1 Series F40.
Manufactured from 2019
Moderators: babybmwadmin, Producethis, marco_polo, Lambster, Rich196
Tumi118i
Post by Tumi118i »
Have 2 issues with my 118i, chirping noise from steering area & also some hard idling at times & car sounds like it’s about to die when the start/stop activates. They can’t seem to figure out the second issue, steering noise issue seems resolved but now the steering seems a lot harder than before (could also be because they’ve borrowed me a 320i G20 and I’ve gotten used to that now). We’re currently waiting for an identical 118i to come so we can compare them side by side as I’m convinced my cold start and idle shouldn’t be that rough, technician reckons it’s normal. Hardly hard the car for 3months now and haven’t really enjoyed it yet.
Steven1077
Re: Hard cold start, Shaky idle and stop/start
Post by Steven1077 »
Turn off the stop/start, job done, I used it for the first time last week and it does what you say, half the time it doesn't seem to be able to make its mind up especially in slow moving traffic
Drives F40 118i :lol: F40 M135i soon :shock:
Previous F30 335d, F32 435i, F21 M135i F22 M235i, F30 340i, F22 M240i F21 M140i
Tumi118i
Post by Tumi118i »
I generally don’t drive with it on either, it’s more the hard shakes and idling that annoy me. Do you know if there’s a way to permanently turn the start/stop off? Gets irritating to have to do it with every drive. My morning routine, Unlock Car, Get in, Turn on AutoHold, Turn off Start/Stop. Wish there was a way to keep the setting like that.
cuke2u
Post by cuke2u »
Through programming disabling the start stop is possible. I just setup my sport individual mode to the way I like, steering and engine to comfort, gearbox to sport. Start/stop is disabled with those settings also, but I still have to press one button - no great hardship is it?
Modes can also be setup to automatically be selected by programming as well...
M235I xDrive Grand Coupe, Snapper Rocks, Pro, Tech and Drivers Assistant Packs, 19" 557M Wheels
Steven1077
Auto hold should only need turning on once, does yours forget it? Mine has a fairly smooth idle when stop/start is dissabled
Justinitus
Post by Justinitus »
I have to press the brake pedal quite hard for auto stop/start to activate, a light press of the brake (like in crawling traffic) it doesn’t come on.
When I first got the car I had to press the auto hold button each time I started the engine to activate it - now it’s on each time I start. I wonder if this is part of the car’s technology learning your driving habits?
2021 118i M-Sport Auto - Storm Bay - Live Cockpit Pro - Sun Protection Glass - Comfort Pack
Tumi118i
Post by Tumi118i »
@Justinitus yes it does need to you to press a bit harder to confirm that you are sure that u want activate start/stop or AutoH, that doesn’t bother me much. I’ll check once I get it back if it eventually “learns” my driving preferences otherwise will try go @cuke2u’s route.
Return to “F40 (2019-tbd)”
