E82 Heated steering wheel retrofit possibility
Post your thoughts in here
--help
Post by --help » Sat Jan 03, 2015 10:51 am
I recently bought an E82 from 2008. Really pleased with it, has heated seats but does not have a heated steering wheel. I did some searching but only found one page where some people talked about this. It seems this was option #248, rare option apparently, but more i cannot find about it.
Does anybody know if it is possible to retrofit a heated steering wheel in my car? Or in E80-series in general?
Re: E82 Heated steering wheel retrofit possibility
Post by marco_polo » Sat Jan 03, 2015 10:54 am
It wasn't a UK option on the E Series, iirc.
I think you're right that S248A is the optional extra code.
--help
Post by --help » Sat Jan 03, 2015 11:35 am
Yes it seems like it, but when i check realOEM it only says about some options "S248A=Yes" meaning that the steering/option CAN work with it (i guess, correct me if i'm wrong) but there is no real retrofit option. What would i need, i cannot find any documentation or information that explains some about this.
Post by marco_polo » Sat Jan 03, 2015 12:15 pm
Does your car have 61319169750 slip rings?
You'd need switch 61319143639 too.
--help
Post by --help » Sat Jan 03, 2015 1:04 pm
When i check 61319169750 i see that it does not support a rain sensor. For sure my car has that. When i check for other slip rings, it seems that none of the heated rings support a rain sensor?
Post by marco_polo » Sat Jan 03, 2015 1:46 pm
I can't find one with a Rain Sensor and Heated either, maybe it uses the same connections?
I've even checked the 3er slip rings, so I guess you're out of luck. :(
--help
Post by --help » Sat Jan 03, 2015 2:22 pm
Are the 1 and 3-series slip rings/steering wheels the same you mean? Weird that it is not possible, sounds like a challenge to find one ...
Post by marco_polo » Sat Jan 03, 2015 4:45 pm
Most 1 and 3 series parts are interchangeable, they're basically the same car (although the 1er is 2" shorter in the rear footwell).
--help
Post by --help » Sun Jan 04, 2015 6:19 pm
Of course, bmw wouldn't be bmw if the production date matters ... when i look up parts from 2010 and later there is a possibility for heated steering! Look at the realOEM site and see that there are numerous options that have the heated option, i however do not see the slip rings anywhere. Anybody knows where i should find those?
RichIbizaSport
Post by RichIbizaSport » Sat Jan 24, 2015 12:13 pm
I have a factory fitted heated steering wheel in my '59 e82 coupe :spotman:
'59 123d coupe
--help
Post by --help » Sun Jan 25, 2015 1:37 pm
Do you have a rain sensor perhaps as well? And do you know the part numbers? 8)
Post by Octavius » Sun Jan 25, 2015 2:47 pm
RichIbizaSport wrote:I have a factory fitted heated steering wheel in my '59 e82 coupe :spotman:
Should be able to trace part numbers on realoem from this.
Glacier Silver 320d lci M Sport.
--help
Post by --help » Sun Jan 25, 2015 7:59 pm
Well i don't know what '59 for example means, not from US. Not even close; Netherlands. And the issue is, as in my initial post, that i cannot find the part numbers on realoem ... So RichIbizaSport, do you have some more information for me? Thanks! :)
Producethis
Post by Producethis » Sun Jan 25, 2015 8:01 pm
I can't remember what the site is but you can call up your vehicle spec ( RichIbizaSport) and if you can do that it might give you the option code for it and work out the parts off that??
__________________
Monacoblau e87 1m
Sparkling Graphite 2008 E82 N54 135i - Daily
Sophistograu Brillanteffekt Metalli 2014 F01 730d - Gone
brilliantrot 1990 E30 318i coupe - waiting to be shown love
RA06 FNH - E87 1m - gone but always in my heart
instagram: producethis
--help
Post by --help » Sun Jan 25, 2015 8:05 pm
Producethis wrote:I can't remember what the site is but you can call up your vehicle spec ( RichIbizaSport) and if you can do that it might give you the option code for it and work out the parts off that??
__________________
Monacoblau e87 1m
That would indeed be helpful, can you share the production code of your car RichIbizaSport please?
