F20 Satnav Retrofit
drumandbass
F20 Satnav Retrofit
Post by drumandbass » Tue Sep 26, 2017 4:52 pm
Hi there, first post been stalking the place a while..
Picking up my 120D Xdrive tomorrow, made the choice for leather interior over sat nav.. think it's the 6.5inch screen.
How easy is it to retrofit the BMW sat nav upgrade? Or am I better off ripping it all out and using an aftermarket system..
Money isn't really the issue but want it to be decent - I had an Audi A3 before and I hated my retrofitted system. But that was many moons ago..
Any help/input very much appreciated.
BMWF21MSPORT
Re: F20 Satnav Retrofit
Post by BMWF21MSPORT » Wed Sep 27, 2017 3:59 pm
Hi Drum,
I have a 2012 BMW 1 series F20 with the standard radio / cd no Nav. I do have Bluetooth (Not enhanced), aux and usb input.
I will be carrying out a retrofit of my current system within the next week or so, I currently have HU_ENTRY I will be replacing that with HU_ENTRYNAV.
The things you need...
HU_ENTRYNAV or NBT or NBT EVO Unit
L7 6.5 CID or 8.8 inch screen
Idrive controller (a Touch control emulator is needed to enable touch functionality if you buy the touch controller)
FAKRA GPS Antenna - plugs straight into the HU and can be placed behind the screen display with sticky tape etc...
NBT Nav / Voice control Emulator - Plug and Play straight into the hu (look at an image of the product it will make sense) this is to enable NAV
You will then need to hook it all up, everything is plug and play to this point. These is a video on youtube (type NBT retrofit - the youtubers account is "Omaar" I think.
Once you successfully plug it all in you will then need to code the unit to the car, a regular E-Sys car coder can do this or you can do it yourself providing you have E-net cable and E-Sys software. This is to make the car communicate with the HU and enable NAV features etc etc.
Total cost for me to date inc all of the above is around £280. I have managed to find a bargain L7 CID 6.5 screen and HU_ENTRYNAV unit.
Emulator for NAV is around £120 on ebay but if you buy from Aliexpress it is no more than £30 inc delivery
Fakra GPS Antenna cost me £6 inc delivery off ebay.
Coding the system cost me £75
Head unit
Screen
Controller
£150
I hope this helps.
drumandbass
Post by drumandbass » Thu Sep 28, 2017 3:44 pm
Yes mate very helpful.
I'm not 100% sure on what I have currently, will post pics etc and I can do most/all the work myself as I work in the motor trade anyway.
The only thing I doubt I could do is the coding as I work with Bosch KTS systems, the coding is a bit lacking but I have a friend who should be able to help.
BMWF21MSPORT
Post by BMWF21MSPORT » Fri Sep 29, 2017 9:04 am
Yeah that's what I've done mate, I'm able to connect it all up but my knowledge lacks when VO coding etc.
I purchased Bimmercode and can code absolutely almost everything but to enable NAV I need to go to someone who can code code via E-Sys.
All the best with the Retrofit, I will be doing mine in the next week or so, just waiting for my emulator to arrive. (Cina EMS :roll: )
Any questions mate you can message me anytime.
Ogb666
Post by Ogb666 » Sun Oct 15, 2017 2:46 pm
Hi just about to do the same retrofit as you the only thing that worries me is the service history showing up on the new setup.did you manage to fit yours?if so any issues with the service history showing?
Gregbrears
Post by Gregbrears » Sat Mar 03, 2018 12:03 pm
Hi, I’ve got a 114D F20. Been to get a satnav & screen fitted but the car isn’t compatible with the sat nav system, couldn’t even get the full list up only got about five drop down menus which were radio & the cars setting etc. Has anyone else had this fitted in a 114D?
Ogb666
Post by Ogb666 » Sat Mar 03, 2018 12:12 pm
What system did you get?did you use an emulator and get everything coded?
Gregbrears
Post by Gregbrears » Sat Mar 03, 2018 12:32 pm
I got a 2016 system. Could it be to new? There was a facelift in 2015. & yeah he coded it but his system wasn’t showing anything for satnav retro fit.
Ogb666
Post by Ogb666 » Sat Mar 03, 2018 4:27 pm
Nbt or business navigation?
GarryK
Post by GarryK » Sat Mar 03, 2018 4:33 pm
Mines a 2015 unit and the Nav worked straight away with the emulator.
Is it greyed out on the menu or just not there at all?
Is the unit definitely a Nav unit?
2012 F20 mineral grey 116i Msport
Gregbrears
Post by Gregbrears » Sat Mar 03, 2018 5:13 pm
Yeah it’s definitely a nav unit. There were no options at, not even greyed out. & I’m not sure if it’s a NBT or business nav. Will it say anything on the headunit? I could post a picture on everything on the back if you like?
GarryK
Post by GarryK » Sat Mar 03, 2018 5:44 pm
Post the unit including part numbers.
Your emulator.
The idrive menu screen etc.
Seems very odd to be honest
Gregbrears
Post by Gregbrears » Sat Mar 03, 2018 6:11 pm
I didn't take any photos as i took it to a BMW specialist & he did it all. The setting I could see was RADIO-Vehicle Info-Settings-Connected drive but there were nothing in the connected drive part. He was confused to, he said it could be the cluster or something? But then he said the car was a fairly high spec when he looked at the potential upgrades which I could have. He said he is speaking with people he knows at BMW to see what it could be & getting back to me but i thought along it was a straight system swap it would be okay. I'm assuming he used a emulator but not 100%. This is what I'm trying to fit.
Webp.net-resizeimage copy.jpg (235.49 KiB) Viewed 5734 times
Ogb666
Post by Ogb666 » Sat Mar 03, 2018 6:36 pm
That’s the correct unit but are you using the emulator with it?also when coding did you remove the original 663 option when adding 606?mine done the same when I forgot to remove 663 ie no navigation and only 5 drop down lists......
Gregbrears
Post by Gregbrears » Sat Mar 03, 2018 6:42 pm
I haven’t a clue what he did, I thought it was just because I had a low spec car but he said it’s not that. I’ll ring him first thing Monday morning & ask if he did those things & used an emulator! I’ll get back to you Monday morning see what he says. Thank you!
