Steering wheel control interface
Giggs
Post by Giggs » Tue Mar 13, 2018 6:06 pm
I wil be buying an aftermarket HU in a few days and thanks to sonic I know I need this lead but does anyone have any idea how to connect everything.
The yellow wire I have to plug into the fuse board for an ignition switch?
What are the open connections at the top of the image?
https://www.ebay.co.uk/itm/CTSBM009-2-S ... SwPCVX5kcU
2008 E87 116i N43 - Some Mods
Re: Steering wheel control interface
Post by Nottsknots » Tue Mar 13, 2018 6:56 pm
http://www.connects2downloads.co.uk/c2/ ... SBM009.pdf
I think those are three of the wires shown bottom left (pink, green and pink/black)
- speed pulse (if you HU has a speed registering capability, or you have a timing unit (for measuring perfomamce etc). Also disables certain features if you're moving (legal requirement).
- parking brake (no idea why that might be used)
- phone mute (useful if you have handsfree)
Not sure why the reverse isnt shown (useful for HUs that can connect to a rear view camera.
Giggs
Post by Giggs » Tue Mar 13, 2018 7:03 pm
Great thanks, I need to connect the red wire off the harness to a +12v ignition switched supply what can i use for this?
Post by Nottsknots » Tue Mar 13, 2018 7:48 pm
I tapped mine into the cigarette lighter circuit. Cant remember which fuse off the top of my head, but thats the easiest way, with an add-a-fuse.
Sonic1506
Post by Sonic1506 » Wed Mar 14, 2018 8:43 am
Speed pulse is to do with Satnav.
Parking Brake is to do with DVD, so you can watch videos on the move (illegal). so you have to connect it to the handbrake (or similar) to allow the unit to play DVD's when the car is parked.
Post by Nottsknots » Wed Mar 14, 2018 6:47 pm
Thanks for the update; never had to use them, so never paid attention, but every day is a school day, so filed that away for future reference :)
Giggs
Post by Giggs » Thu Mar 15, 2018 5:20 pm
Do you think it would be easier to just run the yellow wire to the battery as I've seen people struggle to find a fuse that works for them, as they say after 20 mins their radio settings reset.
Also I've removed the shock absorber and pressed the 2 tabs to drop the glovebox down but is there anything else I can do to access the fuse board more easily?
Sonic1506
Post by Sonic1506 » Fri Mar 16, 2018 8:41 am
If in doubt or you're struggling, take your car to a reputable audio shop and get them to find the relevant place on the fusebox, to fit a breakout fuse.
Giggs
Post by Giggs » Tue Mar 20, 2018 12:01 pm
So I've got an ignition switched wire for the red wire but I also need a permanent live wire for the yellow?
Sonic1506
Post by Sonic1506 » Tue Mar 20, 2018 12:26 pm
Other way round. Your red is permanent live. Yellow is switched ignition.
Giggs
Post by Giggs » Tue Mar 20, 2018 12:47 pm
Great thanks.
