F20 Tweeter Upgrade
Jmaloney
F20 Tweeter Upgrade
Post by Jmaloney » Sun May 06, 2018 7:10 pm
Hi,
Just wondered if the following item is good value? or are better or cheaper options available?
https://www.ebay.co.uk/itm/BMW-GENUINE- ... 1438.l2649
John
OO7
Re: F20 Tweeter Upgrade
Post by OO7 » Mon May 07, 2018 5:03 pm
This is what I used, they're as good as you'll get in terms of keeping under the £100 mark. HK ones cost double that I'm sure.
Jmaloney
Post by Jmaloney » Tue May 08, 2018 6:19 am
Thanks for the reply, I will get some ordered later today 😀
jimBabyBMW
Post by jimBabyBMW » Tue May 08, 2018 6:47 am
They are identical to the HK. You can get the same HK badges to fit in place of the alpine ones.
You'll need the round HK tweeters (9226357)
https://rover.ebay.com/rover/0/0/0?mpre ... 2152703290
and the splitter cables
https://rover.ebay.com/rover/0/0/0?mpre ... 2494452533
Jmaloney
Post by Jmaloney » Tue May 08, 2018 8:20 am
Can other tweeters be used also? is 60 euro, for 2 used HK speakers a good price?
John
jimBabyBMW
Post by jimBabyBMW » Tue May 08, 2018 11:33 am
Your best to buy the proper tweeter, they snap into the frame, it's a round hole designed for them. You can get others, but you'll need to make them fit, which is probably more time and money.
Yes, that's a good price. I paid 65. But that was after spending 50 on the wrong ones. Double check the parts diagram to make sure.
jimBabyBMW
Post by jimBabyBMW » Tue May 08, 2018 11:38 am
It's a great mod btw, made a massive difference to the sound, was totally plug and play and quite easy. Considering most disconnect the centre speaker anyway, you pretty much get the upgrade.
When taking the door card off, be careful of the door lock button.
Jmaloney
Post by Jmaloney » Tue May 08, 2018 3:30 pm
I do like the sound of plug and play! then what other speaker upgrades that are plug and play would you suggest? I wouldn't mind having a discreet amp fitted somewhere as well.
Jmaloney
Post by Jmaloney » Fri May 11, 2018 6:15 pm
John
I have just bought the tweeters you recommended, and the cables. Bought the tweeters new from the company who I bought the tweeter covers from as well.
Any suggestions on front door speakers to look out for?
