2014 1 series sat nav prob
Faye
Post by Faye » Fri Jun 01, 2018 10:43 pm
Hi need some help/advice. Recently bought my 1 series sat nav was working fine until recently but now when i try and use it i get the message cant calculate route. Have tried different destinations and get the same message. I have tried holding the radio button for 30 secs and re booting it but that didnt work. I'm not sure if its a coincidence but i did eject and throw away a copied disk from the cd player ... does the 2014 1 series need a sat nav disk? Is that what ive binned? Or could this be a diff problem?
Any help appreciated.
topuphere666
Re: 2014 1 series sat nav prob
Post by topuphere666 » Sat Jun 02, 2018 10:34 am
You shouldn’t need a disk for it to work, I’d suggest getting it checked at bmw
F20 M135i - auto -mineral grey, heated leather, pro nav and a few other bits
Ogb666
Post by Ogb666 » Sat Jun 02, 2018 1:26 pm
Try this:
In order to fix this issue, all you have to do turn off the engine and turn it back on while holding the volume button for about 30 seconds. After that, take your car for a quick drive around the neighborhood, trying to do a circuit that mimics the figure 8, to calibrate the car’s compass. That’s about it. Problem solved!
Faye
Post by Faye » Wed Jun 06, 2018 12:21 am
Hi ive already tried this but still getting the same problem. Thanks tho
Ogb666
Post by Ogb666 » Wed Jun 06, 2018 8:50 am
Try updating the maps as it seems they are corrupt.i get mine from here:
https://bmw-navi-maps.co.uk
