Hi All,
Currently running a 2006 pre-LCI 130i that has a professional head unit with a fibre connection to the CDC and the MULF1 in the boot.
The MULF1 has kicked the bucket and the CDC is not required so looking to do the upgrade to an LCI head unit which has the USB and BT built-in, looking across the web provides a better listening experience and will be newer.
Found a few on eBay which has the required connections but just want to run it past you good people before I commit. So a couple of questions:
1. As I have had Bluetooth which I assume means the MIC connection goes to the boot, does anyone know if this is one cable or has a connection ie. in the driver's footwell to connect to the head unit?
2. As the USB is built-in and will be looking to put the USB socket under the armrest, does anyone know the part number for the male to male connector cable from the HU to USB socket?
3. As the LCI head unit with DAB is pretty thin on the ground and the pre LCI e87 had the option for a DAB module and I have the fibre network in the car, can the DAB module be coded to an LCI Headunit and put in place of the CDC?
John
John
