A little guide: complete CIC retrofit in my e81 (combox p.2)
jammy78
Re: A little guide: complete CIC retrofit in my e81 (combox p.2)
Post by jammy78 » Sun Mar 22, 2015 7:22 pm
Edit.... it looks like this it's working correctly.... when i go above a certain speed the parking sensors turn off! I'm guessing this is some kind of safety feature? Not sure I like it.... I haven't seen this on the E9x?
awt
Post by awt » Sun Mar 22, 2015 8:37 pm
The PDC screen usually shows after you put the car out of reverse. It will stay on for a little while, then disappear. This is normal in all BMWs.
Bianco
Post by Bianco » Sun Mar 22, 2015 9:54 pm
Doesn't it disappear as soon as you reach 20 km/h (or so)?
jammy78
Post by jammy78 » Sun Mar 22, 2015 11:00 pm
Bianco wrote:Doesn't it disappear as soon as you reach 20 km/h (or so)?
Yeah.... is this normal then?
This doesn't happen in my e92, soon as you take it out of reverse the CIC returns to the screen (radio, menu etc...)
awt
Post by awt » Mon Mar 23, 2015 12:51 am
It's normal. Happens both in the e81 and my e61.
jammy78
Post by jammy78 » Mon Mar 23, 2015 6:41 am
awt wrote:It's normal. Happens both in the e81 and my e61.
Cheers mate!
Any ideas why the service light will come & be over due? I had the battery disconnected for a couple of days?
deneyer
Post by deneyer » Sat Mar 28, 2015 3:25 pm
Hi there, i have a question, i did a cic retrofit and i also want to put in a combox so i have al the extras. My question is whats the partnumbr for the wiringloom, because i have nothing i my car of the wiring thats needed.
So what do i need except the combox?
jammy78
Post by jammy78 » Tue Mar 31, 2015 10:46 pm
Could someone do me a favour & list what they have in the service menu.... I think I'm missing some (I.e oil, rear brake pads.....)
Joe
Post by Joe » Sat Apr 04, 2015 8:33 am
jammy78 wrote:Could someone do me a favour & list what they have in the service menu.... I think I'm missing some (I.e oil, rear brake pads.....)
I will when I'm home Sunday.
Great retrofit!
2010 118i ///M Sport
deneyer
Post by deneyer » Fri May 01, 2015 10:16 pm
Can somebody tell me how to connect the Most cable to the radio, because i don't know how. And i have NO MOST in the car.
redwizard
Post by redwizard » Sat May 02, 2015 10:43 am
deneyer wrote:Can somebody tell me how to connect the Most cable to the radio, because i don't know how. And i have NO MOST in the car.
Not all radios have the MOST socket.
It's not on the (e8*) business unit and not on some pro units.
On my retro fit, the MOST cable goes from the combox to the cic/pro-nav unit.
deneyer
Post by deneyer » Sun May 03, 2015 11:19 am
Mine to, but i did the full install and the combox isn't working. I checked if there is power on wire 1 and 14 and it has, the red light from the most also reaches the combox.
But when i check the settings in the cic to see if i have the bt, there is nothing and if i try to read the combox with ncs or tool32 it gives me an error
COAPI-2020: ECU does not answer IFH-0009: SG nicht angesschlossen oder meldet sich nicht CMEDIAR
And i don't know where the provlem is can it be because it is a combox telematic
jammy78
Post by jammy78 » Sun May 03, 2015 11:24 am
If it's a combox telematics... then the power wire should be going to Pin 2 on the combox
deneyer
Post by deneyer » Sun May 03, 2015 11:53 am
jammy78 wrote:If it's a combox telematics... then the power wire should be going to Pin 2 on the combox
My wires are connecte as follwed
1 Red +
14 Brown -
11 White
12 Black These tree are for the mic
25 Yellow
jammy78
Post by jammy78 » Sun May 03, 2015 12:04 pm
These are the possibilities, so you'll need to rule each one out:
1. Is there power going to the combox - easy way to check, does the most lights come on when power plug connected?
2. Coding
3. MOST wires connected incorrectly
4. Incorrect combox you need a BN2000
You shouldn't need to you tool32 to get the combox working.... not sure why you would go straight to this when the CIC can't see the combox?
It's going to be a matter of ruling eachone out
