E87 cic satnav idrive retrofit
jamesfawcett
Re: E87 cic satnav idrive retrofit
Post by jamesfawcett » Thu Aug 11, 2016 10:25 pm
I didn't question it, but looking again it looks like I can reuse my existing lower trim! Thank you you just saved me some money in this already expensive conversion :cry: did you take the power feed and Earth at the head unit connector too? It does seem like the sensible way to do it, with a removable emulator.
jammy78
Post by jammy78 » Thu Aug 11, 2016 10:35 pm
You talking about the trim that will go round the CIC - this will cost you £20 from BMW. Your existing trim won't fit.
Yes, I tapped into the live & ground radio wires for the power & also the CANs.
jamesfawcett
Post by jamesfawcett » Mon Aug 15, 2016 9:13 am
Managed to find the part number for a facelift LCI dash trim: 51456976847
http://www.realoem.com/bmw/enUS/showpar ... Id=51_6713
Just needed to put in a newer 2011 model of E88/E82 into realoem to get the full list of dash trims.
jamesfawcett
Post by jamesfawcett » Wed Aug 31, 2016 2:04 pm
Thanks for sharing
dangee
Post by dangee » Sun Oct 30, 2016 12:47 pm
Did you ever get this sorted ? I have no signal from my aerial too, really annoying
Mozzy
Post by Mozzy » Fri Nov 04, 2016 5:44 am
Has anyone actually completed this, my factory fit idrive has no power coming up the white plug to the flip up screen, where does the power supply ( White plug under screen) come from
Bimmerlife
Post by Bimmerlife » Mon Dec 04, 2017 9:20 am
Hello V-spec
I was wondering how you connect the screen? Did you make an external harness for the screen and idrive controller? I know there is two plug housing on the screen, one for the comunication/signal kabel from cic Nav HU and the black 12pin plug housing, porbly for power/signal kabel. But how did you get power to the 12pin plug on the screen? And how did you connect the I-drive controller, wich has a 4pin plug housing i believe, and how does it communicate with the cic nav HU?
Is there any wiring diagrams out the for the whole wiring part for cic, screen and I-drive controller? If i need plugs and kabels, where can i buy this?
Thanks in advance
Jase
Post by Jase » Thu Dec 21, 2017 5:02 pm
Impressive work on this guys!
If I have a 2007 car with a CCC Pro already installed is this job a lot easier, is custom wiring still required?
Jason
