How to create a USB BMW iTunes Media Library
jfbach
Post by jfbach » Mon Apr 04, 2016 3:41 pm
Hi, I read lots of posts and forums and tried different options and finally got it working in my 2015's Series 2 even with playlists.
I use iTunes because it's easy to keep your libray organised and to update information as artists, albums, covers, etc...
I explain here how to have your "BMW iTunes Media Library" in one USB
1 - Format your USB as FAT32 and set a proper name :-) . I got a 32Gb and works pretty fast
2 - Start iTunes application and IMPORTANT press SHIFT while it's starting to create/choose a different Library
It will show a window asking to "Create a iTunes Media Library" or to "Select and existing iTunes Media Library"
Obviously we're going to CREATE it but just this 1st time.
Once you press "Create..." it asks for a folder name where to store the libray. I set "iTunes" but you can choose a different one.
3 - Once iTunes appears with your empty library it asks to "Scan folders for music" ... just say no.
4 - IMPORTANT!! Before to add elements, go to "Preferences > Advanced" select the following 2 options:
* Keep iTunes Media folder organized
* Copy files to iTunes Media folder when adding to library
It means that any single file added to this library will be COPIED to the USB and not referenced to its original location and that iTunes will create a directory layout to keep files organized (actually we don't care about this structure but it's good to have it)
So our BMW USB will hold a complete iTunes Media Library
5 - Add your music to iTunes. You can drag and drop files to iTunes window or use "File > Add to Libray..." option.
All files will be copied under your created "iTunes" folder
6 - Add/Modify all music information; Artist, Albums, Covers, Genres.
Cover is important to be shown in the BMW screen but I also suggest to have a proper "Genre" list or at least that's what I use the most.
I mean that instead of genre "rock" use detailed ones as "metal rock", "punk rock", "progressive rock", "gothic rock", etc.. Something handy for the "BMW Music Search"
7 - Create your preferred playlists in iTunes
8 - Browse to your USB and create a folder called "playlist" in the root. For example in windows will be "K:\playlist" and OSX will be "/Volumes/MyUSB/playlist"
IMPORTANT. I tried different locations but my BMW only recognises playlist under this folder
PLAYLISTS EXPORT!!
9 - Once you got your playlist choose "File > Library > Export Playlist" and select USB folder "playlist" and format M3U
10 - iTunes exports playlist with full path to music files but we need to do small replacements to have it compatible with BMW navigator.
IMPORTANT!!
I played with different formats and the only one recognised is starting with ".." and backslashes (\) as separator
Code: Select all
..\blabla\myfile.mp3
Open exported M3U files with a regular Text Editor; Notepad, Sublime, TextEdit, ...
WINDOWS:
File looks like
Code: Select all
K:\iTunes\media\artist...
So just replace "K:\" by "..\" and save
OSX:
File looks like
Code: Select all
/Volumes/MyUSB/iTunes/media...
So we need to replace "/Volumes/MuUSB" by ".." and "/" by "\"
DONE!! you got a full iTunes Media Library in your USB that your BMW can read and play.
To do changes in your library just plug the USB in your computer, start iTunes, press SHIFT and select existing library in your USB
Add or Remove music files, modify information. Your library is updated in your USB
Just in case that you do changes in your playlists, you must repeat the steps 9 & 10 (export and adapt exported list)
Enjoy!!
v-spec
Re: How to create a USB BMW iTunes Media Library
Post by v-spec » Mon Apr 04, 2016 6:38 pm
Bloody excellent, I was just planning this for my retrofit CIC install.
Gonna give it a go,thanks matey!
2008 BMW 118d m sport Sapphire Black
Paul CS
Post by Paul CS » Mon Apr 04, 2016 10:05 pm
A great guide, but am I missing something...
In the nicest way, assume one has an iPhone, why not just synch all the music to the iPhone from the laptop? That way the USB socket on the car can also keep the phone charged. Also, if like me you use Spotify, that can be accessed too.
Am I missing something?
Paul
jfbach
Post by jfbach » Tue Apr 05, 2016 10:08 am
Hi,
you're right, you can use your iPhone with your music so there's no need to do that USB but in my case in my iPhone I got MY music but for my car I need also to have my wife's and my daughter's :-(
In fact I got playlists with the name of each member of the family.
That USB iTunes Media Library is a sub-set of my full Library.
For me is handy because the USB is always plugged (it's a very small one) and I just need to take it in case we wanted to modify the contents.
ferraris
Post by ferraris » Wed Apr 06, 2016 12:55 pm
Or just use iTunesFusion which will do almost all of that for you from your existing iTunes library.
now: F87 M2 in LBB
ex-F21 M140i 3 door in VO
ex-F21 125d M-Sport in VO
ex-Audi TT TDi
ex-123D M-Sport Coupe
5678
Post by 5678 » Wed Apr 06, 2016 1:13 pm
Does this process deal with any DRM issues on iTunes purchased music?
'18 F87 M2 LCI
'15 X5 30d
'04 Clio 182
zaks
Post by zaks » Fri Oct 27, 2017 10:46 am
Great how to guide. You should do a WiKihow.
Is it possible to have multiple playlists? I have managed to get 1 playlist working 100% fine, even managed to add tracks etc. Just cannot seem to have multiple playlists working in the car.
The display shows both playlists on the USB, however just the one has entries in the list. The other merely shows "No entries"
WilliamsA
Post by WilliamsA » Tue Apr 10, 2018 3:19 am
First in first, it is hard to get a USB from iTunes Media Library for all the media contents on iTunes are protected by DRM so all I need to use a tool for me to make all the iTunes Music DRM-free. Here I use TuneFab Apple Music Converter then I can create a USB for iTunes Media Library. It is easy to operate.
Martinling
Post by Martinling » Tue May 22, 2018 9:50 am
You will met some trouble when importing iTunes media library to USB BMW, since media files in iTunes library are protected by FairPlay DRM technology and you are limited to share and transfer them on selected devices. Obviously, USB flash drive is not included in it.
But don't worry, as for iTunes music, like audiobooks, Audible audiobooks, Apple Music, you can use Apple Music Converter for Windows to remove DRM protection and convert them to USB compatible format, like MP3.
As for iTunes movies and TV shows, you can have a try of itunes drm m4v media converter for mac, which works on iTunes movie purchases and rentals.
After conversion, you can freely create a USB BMW iTunes Media Library with ease.
ferraris
Post by ferraris » Tue May 22, 2018 12:28 pm
I believe only old iTunes files include DRM, deleting them and redownloading will download non-Drm versions.
now: F87 M2 in LBB
ex-Audi TT TDi
Daaaavvveee
Post by Daaaavvveee » Tue Sep 18, 2018 12:26 pm
All these posts look spammy with that software link
Present;
BMW M140i Shadow Edition
Past;
2011 Ford Focus Titanium X 1.6TDCi
2007 Z4 Coupe - Gone :(
2010 E82 BMW 120D Sport - Gone
Martinling
Post by Martinling » Tue Oct 09, 2018 2:06 pm
So nice to come back to this thread. I would like to make a clear knowledge about iTunes music files. Please be well noted that iTunes music downloaded after 2009 is not protected by DRM. But Apple Music files are protected still. And audiobook files do so.
If you get DRM-protected audio files, you need to use Apple Music Converter to unlock this limitation and then you will be free to create your USB BMW iTunes Media Library without problem.
