New member - DGJ's 123d
DGJ123d
Post by DGJ123d » Thu Oct 12, 2017 6:23 pm
Hey guys,
So as above I'm new to the forum having just picked up my first BMW last weekend! I've only had one other car that was even slightly performance oriented and that was a Mk 1 Leon Cupra TDI so this is a huge step up!
The car has 130k on the clock but almost all BMW dealer service history and apart from a few stone chips on the front and scuffs on the wheels it's in pretty good condition. It also had a few optional extras that swung me to this particular car.
Specs
Grey E82 123d M-Sport 2008 (58 plate)
18" BMW 261 wheels
Factory xenons
Heated seats
Cruise control
Professional radio
PDC front and rear
Auto wipers/auto lights functions
Brushed aluminium interior trim
Apologies for the autotrader pics...
I'm not sure how much was normal M-Sport fayre but I know the heated seats and xenons add a few thousand to the list price so really pleased with it Image
Plans are currently to replace the number plates with 3d gel ones as the front plate is down to a very papery layer and needs sorting to freshen things up. Then the car is getting 2 new 215/40/18 Toyo Proxes on the front wheels to replace the run-flats as one has a couple of bulges in the sidewall and the other is completely worn on the outside edge! The rears are already non-RFT, currently on Maxxis AS01s in 245/35/18. After that I'll be running the car for a while and looking to do the following later on:
White LED angel eyes
Carbon front grills
Carbon boot spoiler
Gloss black window trim
Number plates (as above)
Smoked side repeaters
Darkline rear lights
Gear knob replaced with a less worn item
Steering wheel freshened up/replaced as well
I'd love to hear your input in to small things I can look at and try and sort while I'm stuck with my mod-unfriendly insurance company Image after that ends and I'm with someone more lenient I'll be looking to do all the above and then anything to help tighten the steering/suspension. Any ideas where's best to start, particularly with any OE bits I could look at?
If anyone recognises the car or if it's been on here before I'd be happy to hear about it and I'm looking forward to learning a few things from you guys as I go.
Thanks,
Darren
AndyBish135i
Re: New member - DGJ's 123d
Post by AndyBish135i » Thu Oct 12, 2017 11:20 pm
Hello and welcome! :)
Camber pin removal and CDV delete are free mods :wink:
People normally go for 225/40 and 255/35 tyres if ditching runcraps...
10 plate N54 135i in 475
6MT/CIC/CC/Xenons/Custom mids/BMWP v1 MFSW+handbrake+gear/Darklines/Zito935/BBMW CF Splitter+Diffuser/SSDD CF spoiler
viewtopic.php?f=19&t=94948
DGJ123d
Post by DGJ123d » Fri Oct 13, 2017 8:26 pm
Thanks Andy!
Yeah both look pretty straightforward, with the camber pins is this worthwhile for daily driving regarding outer tyre wear? Or more for performance purposes?
And can the CDV bypass/delete be done on your own? I saw in the guides that you need someone else pressing the clutch pedal for you while you reconnect everything or is it self bleeding? Sounds like a good idea because I've noticed on downshifts that it can be a bit juddery.
So today I had my tyres changed and it's made a massive difference to the comfort in the few miles I drove home! Potholes and grids are now just breezed over without losing much of the feel of the steering :-) I'll consider going up to 225s when the time comes again but I like the mini stretch on the 215s.
You can see below the wear on one of the tyres though the bulges on the other are harder to see
I also got my 3D number plates today but they got the reg wrong Image so I've been in touch with them to try and get the right ones sorted.
Post by marco_polo » Fri Oct 13, 2017 8:30 pm
Camber pin mod is usually done for more even tyre wear, but you do get slightly better handling too.
DGJ123d
Post by DGJ123d » Fri Oct 13, 2017 8:46 pm
marco_polo wrote:Camber pin mod is usually done for more even tyre wear, but you do get slightly better handling too.
Sounds like a plan then, will it help eliminate the kind of outer wear seen in the picture I posted?
I had a look through the guide and it looks simple enough, is it a wheels off job or just remove the pin, jack up the car, loosen and position the strut and tighten back up?
Post by marco_polo » Fri Oct 13, 2017 8:48 pm
Yup, reduces outer edge wear as it reduces the natural in-built understeer.
Here's a post I wrote recently for someone else: http://www.babybmw.net/viewtopic.php?f= ... 5#p1336631
DGJ123d
Post by DGJ123d » Fri Oct 13, 2017 9:32 pm
marco_polo wrote:Yup, reduces outer edge wear as it reduces the natural in-built understeer.
That was the guide I saw :-D so in that one you just used the wheel brace to pull the top inwards, I presume the car needs to be off the ground for that?
Post by marco_polo » Fri Oct 13, 2017 9:38 pm
I jack the corner up, yes. You can visually see the camber change as you slide them.
I usually use my trolley jack's handle to shift the strut top's inboard, but any kind of lever will do. Use a rag to prevent paint damage.
DGJ123d
Post by DGJ123d » Fri Oct 13, 2017 10:03 pm
Awesome stuff, thanks Marco! I'll be getting on to this when I've located my jack.
Ezzra
Post by Ezzra » Fri Oct 13, 2017 10:12 pm
That colour really suits the car :)
DGJ123d
Post by DGJ123d » Sat Oct 14, 2017 11:07 pm
Cheers mate, really glad I got the grey and the lighter grey still shows all the lines of the car!
I've put a few more miles in the car today and have noticed a bit of a ticking sound on part throttle, it's barely audible on idle and increases with the revs, you can't hear it on full throttle or when above about 3krpm but having read some stories about the timing chain stretch, weak tensioners and cost of preventative treatment if it's any of these it's got me a little nervous! Anyone got any ideas what to look for or how best to diagnose possible issues?
I do have a limited warranty but with the car being higher mileage it's only basic coverage for engine/gearbox and so on and covers about half the labour costs, not sure how much investigation work it covers so want to check things over and rule things out before I spend any more money!
git-r2
Post by git-r2 » Sat Oct 14, 2017 11:30 pm
Looks really nice mate and doesn’t the 123d come with the elsd?
Seen some great vids on YouTube of these drifting, like the idea of drifting a diesel :)
'13 M135i standard.. and will remain so.. I promise... really.. will not modify... or abuse on track..
'91 R32 GTR... basically standard and unmolested... 497 @ rear hubs... never raced nor rallied : https://youtu.be/jhsX0elVG2k
+ some dullness
DGJ123d
Post by DGJ123d » Sun Oct 15, 2017 8:42 pm
git-r2 wrote:Looks really nice mate and doesn’t the 123d come with the elsd?
Thanks mate :-)
Yeah I believe it does but I haven't had chance to try this out yet! It's more of a ESP function that keeps the inside wheel from spinning up more than the outside wheel so that they both move in sync from what I've read on it, should keep things interesting when the wet weather comes! Image
DGJ123d
Post by DGJ123d » Sat Oct 21, 2017 10:24 pm
My 3D number plates arrived this week (with the correct reg) so I spent a few mins yesterday fitting them to the car. You can see how papery and faded my old front plate was I comparison!
The back plate was in much better condition but the plastic film was starting to crack at the edges.
They've really lifted the look of the car, makes it look a little fresher. I'll be looking to debadge the rear soon and then focusing on the LED angel eyes and hopefully getting Darkline lights for the rear.
DGJ123d
Post by DGJ123d » Mon Oct 23, 2017 4:02 pm
I've just completed the camber pin removal as per Marco's guide above and pulled the strut tops in as far as they'll go. There's barely any visible difference with the car back on the ground but hopefully it'll keep me from wearing out tyres so quick and maybe give a slight improvement to overall steering!
I also debadge the rear but no pics I'm afraid, though I'm sure we all know what a debadged 1er looks like :-P
That's all for now :-)
