Quick Question - Debadging
All other aftermarket mods
CynicalRobot
Post by CynicalRobot » Fri May 04, 2018 12:13 pm
Hi All,
I am thinking of removing the M135i badges from the boot and just wanted to check i have the right idea before i go ahead!
My idea is to mask off around the badges, heat up the badges with a hairdryer then try and pry them off with a pry tool, something plastic like a credit card.
Once off i was going to heat up the left over glue again and and then dab some glue gone on the glue and peel it off - https://www.amazon.co.uk/Goo-Gone-Origi ... =glue+gone
Is this the best way? I ready somewhere people have used fishing wire?
Thanks!
2016 BMW M135i LCI - Total Loss :cry:
AndyBish135i
Re: Quick Question - Debadging
Post by AndyBish135i » Fri May 04, 2018 12:16 pm
Yep, hairdryer and fishing line or dental floss to remove the badge...
Then remove the leftover adhesive as you say :wink:
Barney McGrew
Post by Barney McGrew » Fri May 04, 2018 12:22 pm
As above run floss behind them.
Never be tempted to pry them off though, even when they are starting to come loose.
All that happens is you lift one edge and there's a risk of the other side digging into the paintwork.
2017 M140i
jimBabyBMW
Post by jimBabyBMW » Fri May 04, 2018 12:27 pm
Better still, leave them on.
CynicalRobot
Post by CynicalRobot » Fri May 04, 2018 1:05 pm
Oh yea good idea about floss!
I think i have some ocd disorder Jim, i just wanna see how the car looks from behind with the badges off, it will be pretty symmetrical i hope! :lol:
MattR8700
Post by MattR8700 » Fri May 04, 2018 6:29 pm
Dental floss and a hairdryer will do the trick. You may need a little elbow grease and sticky stuff remover to get the last bits of foam off.
- Black 2009 E87 118d MSport -
Iany
Post by Iany » Fri May 04, 2018 7:52 pm
+1 for hairdryer and dental floss. I cheated this time round and got the dealer to de-badge it
dweino
Post by dweino » Sat May 05, 2018 6:20 pm
Defo dental floss, but I used hot water instead of a hair dryer. Came off in no time.
Stumps
Post by Stumps » Sun Aug 05, 2018 9:19 pm
+2 for hair dryer and a plastic pry tool and masking tape so not to damage the paint work.
Isopropanol is the best for removing glue but watch your paint lots of water and polish after.
Good luck. :spotman:
Petery
Post by Petery » Sun Aug 05, 2018 9:47 pm
Ive just done mine. Hair dryer and plastic card. Then a little bit of t-cut to take the last of the glue off. A quick polish and it looks awsome. Well worth it.
