IRP v3 short shifter install 130i e87
All other aftermarket mods
Rustle
Post by Rustle » Sun Jul 01, 2018 8:15 am
I’ve had a CAE shifter on my wish list for some time but struggled with cost. Then found this IRP shifter at less than half the cost. As fate would have it a friend of a friend is a chap called Neil at Carbonmotive in Kent, an e82 owner and the uk distributor for these.
Install was fairly easy but fiddly. Removing the shifter is dead easy, I also eventually found it desirable to remove the centre console just to allow enough room to fiddle about with the base mounts etc without cutting your hands to pieces; and that upon trial fitment it became obvious that I would need to trim the ashtray to fit around the IRP gubbins. I followed a diy for shifter removal, then one from a m3 for the underbody stuff. Whilst they are very different undercar, the process was the same. https://www.m3post.com/forums/showthread.php?t=1272572 I didn’t take many pics. I found all this was possible without disconnecting the drive shaft, but it may have been easier to do so.
Process
- remove shifter surround, knob, gaiter & shifter itself (turn the plastic bit surrounding the ball joint anti clockwise with needle nosed pliers)
- if you haven’t beforehand get the car level on axle stands and make sure you have enough room for your fat gut. Adjust height twice as I didImageImage
- remove the middle two undertrays only. These afford your jack access to the gearbox.
- I also removed a undertray hanger and an exhaust bracket just for room. These are obvious once you try to get your jack in position.
- unbolt the silver heat shield and slide it backwards to the rear of the car. It might object but it will go. to do this you also need to unbolt the small strut brace (13mm)
- position jack under gearbox. I used a piece of 9mm ply between jack and box.
- I decided to only unbolt the lower gearbox mount nuts, then loosen the four of the transmission carrier. All 13mm. Torque value for these six is 19Nm.
- the metal gear pivot (the bit the ball on the shifter sits in) you are removing has two clips at the front. These rotate downwards to release, then you slide the shaft out of the mount (towards outer edge of car) to release. I found I needed to pry the outer edge out slightly to get mine moving. Once these clips are out and the gearbox as low as possible, slide the gear pivot thing all the way forward out of its rear mount and it’ll pop free.
- back up top to select your shifter position then drill your mounting holes.
- back under to find the supplied bolts are too short and that bmw has glued some fairly dodgy sound deadening to the underside. Hack away at this with a Stanley knife to allow you room to move, and fit your washers and nuts.
- Installing the bolts is a two man job. The rear bolts are easy as you can get a ring spanner under the IRP frame from the topside through that massive oval hole. The front ones are a pain as you need to work around the guibo which restricts hand positioning. Well it did for me. But it got done.
- back up top for final checking , then fit the oem rubber boot.
- back under to connect the linkage pin to the shifter and reinstall the oem circlip.
- back up top to play around and fine tune the limit adjusters on the IRP shifter.
Jobs a good un.
E87 '05 130i; BMWP Brakes, intake, & exhaust. birds arb's, quaife, meister R coilovers, m3 lca, goodridge lines, oz Ultraleggera and 595 RSR's.
Re: IRP v3 short shifter install 130i e87
Post by Octavius » Sun Jul 01, 2018 10:51 am
A nice job but it sits far too high for me.
Is your car a track car or a daily ?
Glacier Silver 320d lci M Sport.
Rustle
Post by Rustle » Sun Jul 01, 2018 6:10 pm
Octavius wrote:A nice job but it sits far too high for me.
It’s what I’m calling my clubsport. I mainly use it on track days and drive outs etc but it doubles as a second car from time to time. I’ve just driven it for the first time; you might just change your mind if you try it, feels absolutely spot on (sits really good with you elbow on the arm rest) and not over kill for a daily, though cutting the console to bits may be a bit much for some.
Rustle
Post by Rustle » Sun Jul 01, 2018 6:13 pm
I have a video but no idea how to load it via tapatalk. It is on the Facebook group ‘130i owners unite’ for those who have joined it.
Rustle
Post by Rustle » Sun Jul 01, 2018 6:19 pm
You tube link here https://youtu.be/eXg1IWR7pQ0
tbt
Post by tbt » Tue Jul 03, 2018 10:59 am
I find the stock shifter sits far too low for me. The arm rest gets in the way of full elbow articulation when your hand is on the shifter.
I know that some people have removed the armrest to make the ergonomics better, but this looks much better as less distance for your hand to move to the shifter and back is massively reduced.
On a rough road at speed you don’t want to be taking your hand off the wheel a moment longer than possible.
2006 E87 130i BMWP Parts-[Exhaust/Intake/Fr & Rr Brakes/Strut Brace/SS Kit]
M3 Parts-[Rear Subframe/Rear upper arms/Front Tension & LCA]
Quaife LSD, Bilstein B12 kit, Megan Racing toe arms, E46 M3 trans mounts, CDV delete
markhurley
Post by markhurley » Wed Jul 04, 2018 6:41 am
That’s awesome dude, the extra length on the shifter will help massively on track , it always puzzles me why people go for short shifters :)
130i Birds B1 suspension,M3 front arms,M3 rear arms,Powerflex inserts ,BMWP strut brace,M135i front brake's,BMWP rear brake's, 28mm M3 front roll bar,20mm white line rear roll bar ,Quaife LSD,MPSCup2tyre's,Carbotech pads.
Post by marco_polo » Wed Jul 04, 2018 6:53 am
People like to make the ergonomics worse, and the already slightly agriculture gearbox feel even notchier!
I know of Neil at CarbonMotive, what's he done to his E82 so far Rustle?
Rustle
Post by Rustle » Wed Jul 04, 2018 8:55 pm
Not too sure myself Marco, he’s a friend of a friend and I’ve only spoken on the phone so far. It’s had the IRP shifter (v2 version) and guibo as far as I know, plus a new paint job recently.
shrjun
Post by shrjun » Thu Jul 05, 2018 6:54 am
Does the console have to be chopped up like this :shock:
2014 F20 116i M sport manual HK audio 18" BBS CH-R Lightweight Performance front lip Storm motorwerks V2 titanium gear shift FTP motorsports intake and charge pipe Wagner Evo 2 Comp IC Remus axle back MHD S1
Post by marco_polo » Thu Jul 05, 2018 7:58 am
To fit an IRP, yes.
Rustle
Post by Rustle » Thu Jul 05, 2018 8:29 am
I think so. You can alter the orientation of the shifter as it’s function is not affected by which way it faces so it might be possible to position it within the space without major surgery but IMO it would cause a compromise over ideal Positioning. But the consoles are cheap and easy to replace. Also bear in mind I’ve chosen not to install a shift boot as I like seeing the mechanism. That would cover a few sins in itself.
