Hello peeps, I'm looking at upgrading my 2010 E82 125i 330mm front brakes to the 340mm M135i 4 pot calipers. I've not got £££'s to spend so standard pads and discs etc.
Couple of questions?
I want them black (and without the //M sticker of course) so looking at buying the calipers above and doing the paint job myself. How easy and what do I need to make them a half decent job?
I've been recommended Mtec discs and M4 brake pads, anyone have a decent link to the right discs/pads?
Brake wear sensor? Same as E82 or need a different one?
Tempted to just buy a brake disc/pad/sensor kit like this so there's no balls up -
As above I repainted mine matt black and silver brembo stickers
FInish depends how much work you put into the prep really, I gave mine a light sandblast to remove previous owners yellow paint and key the surface for new paint, came out quite well considering it was a pretty quick job, they have got a bit marked but easy enough to touch up.
Discs and pads wise avoid drilled discs if going on track and pads then M4 are a good allrounder for road/mild track use.
Hmmm that's going to add another £150 to my already tight budget.
So I've got Textar pads and discs and some £25 decent racing brake fluid (can't remember name). Won't be getting braded hoses (unless I break the ones I have). Happy enough with this set up (unless the pads are **** lol)
Repainted the calipers -
Just waiting for HT clear coat and they'll be ready to go on.
New discs painted -
Again, waiting for clear coat.
Painted rear hubs and calipers. Not my best work but they look miles better than they did -
Hopefully in next couple of weeks I'll have them fitted.
Hi Twenny, where did you buy the discs from? I might be upgrading the sticky OEM calipers on my E87 to M135i items shortly. Looking forward to seeing how these look on your car.
45K members
