Fastest E82 135 Nürburgring Nordschliefe times?
All other aftermarket mods
Moderators: Lambster, Rich196, marco_polo, Producethis, babybmwadmin
Finfast
Post by Finfast » Mon Aug 13, 2018 6:12 pm
What are people’s fastest E82 135i Nürburgring Nordschliefe times?
Finfast
Re: Fastest E82 135 Nürburgring Nordschliefe times?
Post by Finfast » Mon Aug 13, 2018 6:15 pm
Mine has jb4 and running about 400bhp, I think the car is probably capable of at least a 7.50 btg on a clear run..?
docwra
Post by docwra » Wed Aug 15, 2018 2:58 pm
8.24 IIRC but plenty to come off of that, it was my first time there. Sub 8 should be easily achievable with good driver, good track knowledge and a few mods :)
Finfast
Post by Finfast » Thu Aug 16, 2018 5:46 am
A lot of the German boys run e82 1Ms and look like they go well just curious what a 135i would actually be capable of, I managed an 8 on tired (Scuse the pun) toyo r888rr having been held up a couple of times and slowed through a yellow... so sub 8s a definite I’m just curious how fast they can really go on a properly set up car?
Zombie_Head
Post by Zombie_Head » Sun Sep 30, 2018 8:25 am
Alex Hart was able to get 8 mins dead on his E8x 130i.
That run he has KW Clubsport 2 way coilovers, stock discs and calipers (unsure which pads), full stock interior, no LSD, no sway bars, no M3 arms or rear bushings and upgraded brake fluid (unsure which one and unsure if SS lines were used).
He was running OZ Ultraleggeras 18x8 ET 40s with 235's cup 2 tires and MAYBE a BMW Performance short shifter and 1/2 cage.
https://youtu.be/HFZDqU4r0c0
Later, he changed a lot such as pole position seats, upgraded/tweaked cam (claimed 20hp more), and added sway bars (again unsure which brand), he also spent €4K on new front and rear brakes (some aftermarket brand i can not recall) and added the 135i mid exhaust and some interior weight savings.
The car was setup by Raeder Motorsport (including alignment) back in the day, before they merged with Manthey Racing. and this way 5+ years ago before changes were made to the ring maker it safer and a bit faster.
Good setup and a good driver = no need for some crazy power.
He never upgraded to M3 arms up front or M3 RSFB or a LSD, he moved on to the E36 M3, E46 M3 and finally the E92 M3. So theoretically, he could had squeezed out a bit more if he kept the 130i.
2012 E82 125i - VIN 51467 - 330i/130i front discs (330x24) - Alpine White - Brown Leather
