Just finished two retrofits 1- Folding Mirror 2-Kafas 2 and Speed Limit Info
I bought a secondhand side mirror with folding and dimming option.
I also got the window switch block with folding button.
I used by Viper installation write up and it went without problem.
The wiring was very easy and involved only 3 sets of wire needing o be spliced. So I can confirm using VIPER's instruction as in the above link the retrofit is one of the easiest retrofit ive done.
Kafas 2 Retrofit - I can confirm that this retrofit works and SLI works after FSC code was entered.
I will try and write of my experience.
Ray
Ray
