How To Change Your Diff Oil
Fullback15
Re: How To Change Your Diff Oil
Post by Fullback15 »
Thanks Marco, API GL-5 stamped on both oils.
Sounds pathetic but will get someone locally here to change it!
waldorf
Post by waldorf »
Today I changed the oil. I have a straight forward 118i. I used a large syringe with a pvc hose. I would suggest to use a pretty rigid hose like the light blue festo air hoses. The pvc hose was too flexible, so it was difficult to get the oil out. I think a piece of festo hose and a 90 degree coupler would even be better to direct the hose downwards. The filler opening is facing a bit upwards, making it more difficult to get the hose pointing to the bottom.
Return to “How To's”
