How To: Upgrade to Facelift Rear Lights
AdamG
Re: How To: Upgrade to Facelift Rear Lights
Post by AdamG »
Ukrpg
Post by Ukrpg »
Morning. I've done this upgrade and all lights work as they should. I do have an issue though as when you put the car in reverse the broken bulb warning light comes on the dashboard - its only when you put it in reverse but have checked and the lights are working - is this a coding issue?
Thanks for any help in advance!
Polar
Post by Polar »
Will be on the list of things to do when i buy a 1 series, thanks
Kimitech
Post by Kimitech »
Please, could you give me some info or guide, how to code the rear facelift led lights to work like they actually should? That means just the led bars were light up until you hit the brakes or turn on the fog lights?
My car is an 12/04 e87 120d with factory fitted automatic headlamps - xenons.
redwizard
Post by redwizard »
Kimitech wrote:Please, could you give me some info or guide, how to code the rear facelift led lights to work like they actually should? That means just the led bars were light up until you hit the brakes or turn on the fog lights?
On the 'Hi' version of these lights (for xenon equiped cars), the LEDs are the running lights and as such are on whenever the main or sidelights are on or in DRL mode (if activated).
For these lights there should be an additional wire (for each unit) linked back to the footwell module (FRM). This is the proper way of controlling the LEDs although some people fudge it by wiring them to the number plate lights.
Although the full set of halogen bulbs are present, the "normal" lights are coded off and the brake lights coded so that the bottom set light up on normal braking with the top set coming on only with "full beans" braking.
Kimitech
Post by Kimitech »
This is the part I do actually know. I was just asking for the coding details - how to make it.
Anyway thanks.
And just to add some infos - my car does not have the option of setting the DRL (angel eyes) so it´s got probably the old FRM module.
redwizard
Post by redwizard »
Kimitech wrote:This is the part I do actually know. I was just asking for the coding details - how to make it.
Anyway thanks.
Ah, OK - the full xenon upgrade was coded for me so other than using something like the Carly app I can't help you there.
Yes, the DRL option was only brought out with later FRMs - you'll probably need an FRM3 "MAX" for this.
blingers
Post by blingers »
For your e87 (prefl) just add +MUEB to your VO and code the FRM. That is what i did for my prefl e87 for the led bars.
moraywalker
Post by moraywalker »
I've just followed the excellent guide for installing the black lines and all looks good!.........
......except my reverse lights no longer work! :?
My pdc still works, I've put new bulbs in on both sides, I believe the wiring is correct, but still nothing......
Has anyone's else found this and fixed it? Or any other suggestions?
Many thanks in advance for the anticipated fix!!!!!
Tommo
Post by Tommo »
Did you swap the cables as per the photos above? (I am presuming you have a pre fl? May help by putting it in you signature?)
Tom
2010 C63 AMG - Milltek cat delete & factory Carbon
2006 130i M Sport - lots of goodies
2008 118d Edition ES with Msport body kit & interior
moraywalker
Cheers fella!
Got it sorted now!
Kimitech
Post by Kimitech »
Could you specify the procedure of adding the +MUEB to my VO and what to code in the FRM?
Jii5
Post by Jii5 »
Hey, can someone post picture facelift tail light bulbs holder where is all needed bulbs install. Is one holder empty in both side? Thanks.
Anish1993
Post by Anish1993 »
Jii5 wrote: Is one holder empty in both side? Thanks.
Yes
Jii5
Post by Jii5 »
Yes
Okay, thanks.
Return to “How To's”
