How To: Upgrade to Facelift Rear Lights
Amz
Re: How To: Upgrade to Facelift Rear Lights
Post by Amz » Sat Jul 23, 2016 8:25 pm
Used this guide today and it was spot on :) cheers!
'04 E87 116i SE - Quartz Blue
'09 Suzuki Bandit 1250
TimG
Post by TimG » Fri Sep 02, 2016 10:13 pm
I followed the guide but my reverse light and indicator were round the wrong way, on the right side light. The fix for this was to swap the black and blue with the brown and blue.
E87 120d (M47) ///M Sport
golfer
Post by golfer » Tue Dec 06, 2016 1:55 pm
Does anyone know why there is an empty bulb holder in an fl rear lamp. I assume it's for use in a different lamp.
2006 E87 130i M sport - LMB - Black Leather - Slowly being cosmetically modded.
redwizard
Post by redwizard » Tue Dec 06, 2016 3:38 pm
golfer wrote:Does anyone know why there is an empty bulb holder in an fl rear lamp. I assume it's for use in a different lamp.
Two fog lights?
golfer
Post by golfer » Tue Dec 06, 2016 3:50 pm
Two fog lights?
Don't think so mate. If you put a bulb in it would only light up a small void inside the casing but wouldn't show through. That's why I think it's the same bulbholder that fits a different lamp maybe. Thanks for your input though :)
redwizard
Post by redwizard » Tue Dec 06, 2016 3:54 pm
So it's the same for both units?
It's been so long since I last opened mine but I remember adding the second rear fog light.
john lummis
Post by john lummis » Sat Dec 24, 2016 12:31 pm
Hi, I'm new to this site, I'm going to be changing my rear lights in the next few minutes and I've found this discussion so useful,especially regarding the wiring, fantastic info and saved me visiting an auto electrician, thank you all
teeb
Post by teeb » Mon Oct 23, 2017 12:04 pm
A big thanks to gg8tcw, I've successfully switched the rear lights and the result is great. Even the wife agreed!
E87 118d 2006 - added MFSW + CC & LCI tail lights
servicebasketusa
Post by servicebasketusa » Thu Nov 16, 2017 4:39 pm
I thinks you have to take expert mechanic services only, not work with demos.
redwizard
Post by redwizard » Thu Nov 16, 2017 5:09 pm
We tend not to trust some "experts" over here and this is easy (and a lot cheaper) to DIY.
Samson
Post by Samson » Tue Nov 28, 2017 10:54 am
I'll try it your way.
Soon I'll be able to play vogueplay uk. There is no doubt about that. I think I've found the best place for gamers in the world.
Bunford
Post by Bunford » Sun Dec 31, 2017 8:25 pm
gg8tcw wrote:
Fri Oct 09, 2009 8:11 pm
Now it's time to re-arrange the wires as per Tigor's guide:
old left side -> new:
1 - black/purple -> blue/green
2 - green/yellow -> green/yellow
3 - brown -> brown
4 - empty -> empty
5 - blue/green -> black/purple
6 - green/purple -> green/purple (my wires were actually grey and purple)
old right side -> new:
1 - green/yellow -> blue/brown
2 - blue/brown -> green/red
3 - brown -> brown
4 - empty -> empty
5 - green/red -> black/blue
6 - black/blue -> green/yellow (my wires were actually grey and yellow)
Great guide. Just doing this now to my car, finally!
However, followed the wiring in the guide, as suggested by Tigor, and mine don't seem to match up. Colours etc are the same, and put them on the same order, but lights are different.
Here is my result from using your wiring:
Left Passenger Side:
- Top red running light working fine
- Top red light glows bright on pressing brake pedal
- Top red light glows bright when fog lights turned on but do not change when brake pedal pressed
- Indicator light doesn't come on and dash icon is hyper flashing
- Lower red light is not active under any situation
- Reverse light working fine
Right Driver Side:
- Top red light doesn't change on pressing brake pedal
- Top red light doesn't change upon turning on fog lights
- Indicator light working fine
- Lower Red light is active as running light
I've a feeling I've got some trial and error coming up! Anybody else had similar issues in the suggested wiring not working properly?
This guide made the actual process super easy though, so thanks for that!
Bunford
Post by Bunford » Mon Jan 01, 2018 12:00 pm
I've got it mostly working now bar the break lights. Both indicators, reversing and fog lights work fine.the running lights seem to work fine too. The only issue is that when pressing down the brake pedal the lights don't seem to brighten, and I can tell they are not as I can see the brightness step when turning on the fog lights.
Any ideas?
zapot
Post by zapot » Fri Mar 15, 2019 2:11 pm
Awesome guide, I've just purchased an E87 and this is my first cosmetic enhancement! Thanks
HHone
Post by HHone » Sun Apr 07, 2019 3:51 pm
Hi,
The rear light upgrade looks great.
I'm looking at doing this to my pre-facelift car. I've read that upgrading to the LED lights are more involved so I don't want to go down that road. Visually what are the differences between the LED and non LED lights as i'm trying to get some from ebay but can't tell for sure in the pictures.
Regards Tom
Return to “How To's”
