Get to your PDC unit (water issue)
SmurfN
Re: Get to your PDC unit (water issue)
Post by SmurfN » Fri Oct 20, 2017 7:16 am
quick question, whats the easiest way to just replace one of the rear pdc sensors? i have the msport bumper. so im wondering if easiest to just remove the diffuser and reach up? or do i need to remove the whole bumper?
Baggio10
Post by Baggio10 » Fri Jan 05, 2018 11:00 am
Great post!!!
You've just helped me resolve this issue on my 2010 E87.
After taking out a pint or more of water from the well the PDC was in, does anyone have any recommendations to check where the water came from, attempt to reseal any issue?
Thanks again
Rarebit
Post by Rarebit » Fri Jan 05, 2018 12:43 pm
Great post!!!
Thanks again
Check rear light seal, rear bumper vent and the round drain hole in the top corners of the tailgate opening
2013 M135i - :spotman:
130i LE - gone
N11dyy
Post by N11dyy » Sat May 12, 2018 12:57 pm
Hi everyone, I am new to the forum, although have read a lot of posts mercer posted anything. But I need some help with finding where I can locate my 635d pdc unit? My front and rear pdc is not working at all.
stevesurrey
Post by stevesurrey » Sat May 12, 2018 1:17 pm
Find your car here https://www.newtis.info/tisv2/a/en/ using your cars VIN. Click on Repair Manuals and then section 66 Distance Systems etc
N11dyy
Post by N11dyy » Sat May 12, 2018 11:14 pm
Thank you so much for the reply. Will give this a shot tomorrow.
[quote=N11dyy post_id=<a href="tel:1403737">1403737</a> time=<a href="tel:1526126259">1526126259</a> user_id=39723]
[/quote]
ramjam2005
Post by ramjam2005 » Thu May 31, 2018 3:35 pm
Hi New member here, owner of E88 118i Convertible 2008. Found this thread as been searching water ingress issue in boot. Unfortunately, with the E88 convertible its a more costly issue as the roof motor/hydraulic pump is squeezed into that same RH boot well where the PDC resides and yes motor is kaput ! Cream crackered ! Main dealers quote over £1200 for a new roof motor/pump alone ! Read through the whole thread hoping to find the source of the water as I don't want to install my refurbed exchange roof pump motor (£199 from http://roofmotors.co.uk ) only to get that soaked too a few months down the road.
I stripped out the RH boot well last week to get to the motor and found the usual puddle in the bottom but the foam rubber shroud which encases the motor/pump acts like a sponge and retains the water. I left all this open to allow it to dry out. Now,its worth noting that I haven't driven the car for nearly a week since then and its just been sitting on the drive. I went to the boot last night to show my son and low and behold the well had re-filled with 2cm of water. Yes, we have had some heavy rain storms this week but the car has just sat there so where is this water coming from?
My son and I was of the opinion ( as most in this thread ) that the black clip-on vent is the culprit - but how? I will try the silicon sealant fix as described and will also check my rear light clusters for leaks. Has anybody considered water ingress via the petrol filler flap ? Obviously being a convertible there could be a multitued of sources for the water but if all the other body shell variants have this same issue it has to be something common to all. Off now to search for a roof motor thread.
Scott&kim
Post by Scott&kim » Sun Aug 12, 2018 8:51 pm
I've taken the pdc out years ago because of the water issue, but my on board computer keeps on flicking through the options and puts different warnings on the dash ie low oil, low coolant etc. Could this be damage caused from the water?
Also my BMW is a 57 plate so the problem is after the suggested 56!
Unfortunately I need to replace the parking sensors as bmw can't complete the recall of there not plugged in😡
There also not owning up to the leak being there fault on the first place 😡😡
bjt
Post by bjt » Mon Aug 13, 2018 12:36 pm
Think this issue affects later cars too, my 07 had water in the PDC well.
Make a small hole in one of the plastic bungs as a fail safe drain.
JMB2018
Post by JMB2018 » Tue Dec 11, 2018 8:34 pm
Hi guys,
I have a professional head unit which was fitted when the 2004 e87 1 series was manufactured - but I am having sensor issues. Should I have an option on my menu for PDC? I don't have any buttons or otherwise in the car, so figured it should be showing on the radio menu? And if so, I assume it could be a coding issue?
Cheers,
Josh
stevesurrey
Post by stevesurrey » Wed Dec 12, 2018 12:59 am
I have no button or HU menu options for PDC but I only have rear sensors. I think that is normal and you only get a button if you have front PDC too. Rear PDC should be activated by selecting reverse gear and deactivated when put back in neutral. I guess there is a reverse gear sensor and if that is faulty I suppose that could stop your PDC working. Heres a full write-up of the system.
https://www.newtis.info/tisv2/a/en/e81- ... ol/2NTGDBK
Nottsknots
Post by Nottsknots » Wed Dec 12, 2018 7:53 am
The clips on the vent break, so its no longer clamped either side of the body panel, leaving a gap water can get through. It may look OK, but any gap is big enough to leak. You dont need to drive and throw water at it, it just runs down the bodywork, behind the bumper panel, and into the boot. Just 1 drop per minute past the seal gives a pool in 24 hours.
Also, drill a couple of 2mm holes into the grommet at the bottom of the well; they’ll allow any water that does get in to drain out. Worked on mine before it was properly sealed.
cmacv
Post by cmacv » Fri Jan 11, 2019 1:44 pm
Last year i had loss of the reversing sensors but did nothing about it.
Recently I have had the christmas tree of lights. ABS, DTC, red warning symbol. The engine would intermittently lose power if i drive away, i can hear a relay clicking away. A way around this was to turn of the DTC and it drives fine, obviously not advised.
After seeing this post it was interesting to find that my issue may be connected to water ingress of the PDC. Opening it up confirmed this and the electronics are completely gone. Heavy corrosion internal.
I have removed the unit, the two connectors left to the side. Yet i still have the christmas tree of lights and car cutting off, rectified by disabling the PDC. Would it need a good PDC in place to resolve the issue, or something else a miss perhaps?
Post by marco_polo » Fri Jan 11, 2019 2:46 pm
I would start here: https://babybmw.net/viewtopic.php?f=29&t=104231
Return to “How To's”
