How To Change Your Gearbox Oil
whodareswins1
Re: How To Change Your Gearbox Oil
Post by whodareswins1 » Sun Dec 29, 2013 5:35 pm
So is there one or two plugs on the diff?
F20 116i
rob180bhp
Post by rob180bhp » Sun Dec 29, 2013 5:36 pm
Most of them stupidly have 1 just a fill plug
Mines has 2 because im posh lol
Instagram "rob180bhp"
thomsonfrase
Post by thomsonfrase » Fri Apr 25, 2014 7:58 pm
Thanks for this Marco.
2 Litres of Red Line MTL and 1 Litre of the Differential oil you speak highly of by Red Line on order from OpieOils :)
FirBim
Post by FirBim » Sat Dec 27, 2014 1:10 am
whodareswins1 wrote:Looking to do this soon with Redline as I have a notchy gearbox. The process looks pretty straight forward. I have some ramps but hate using them. Does using the ramps affect the volume of fluid going inside the gearbox?
Yes, it does. Did mine tonight, following Marco's excellent how-to. I realised (after refitting everything and lowering the car) that I had overfilled. Two 950ml bottles of Redline MTL is 1900ml, so I should've had about 300ml left in one bottle. There wasn't that much, maybe 100-150mls.
I jacked it back up, using the front jacking point on one side and the rear jacking point on the other side. This allowed me to lift the car more 'level' until there was just enough room to wriggle under. Dropped the undershield and removed the filler plug, and about 150-200mls drained out. Wiped clean, put everything back again. Mental note to remember elementary geometry in future....
2010 E87 120d M Sport, Le Mans Blue
Rarebit
Post by Rarebit » Sat Jun 06, 2015 6:03 pm
Did mine today (130i LE) following this guide, nice and easy.
I couldn't get a syringe so bought a small transfer pump for about 7 quid..I was worried once I had the old oil out, this thing wasn't going to pump it back in....but it worked a treat!
https://www.tetrosyl.com/tetconnect/too ... ls/STA164-
130i LE
Polar
Post by Polar » Sun Sep 27, 2015 7:56 pm
Another core mod/maintenance mod, thanks :)
Beasted
Post by Beasted » Mon Sep 28, 2015 1:13 pm
My choices for gearbox and diff oils are...
Diff oil.
http://www.opieoils.co.uk/showproduct.a ... n-5-75w-90&" onclick="window.open(this.href);return false;
Gearbox oil.
http://www.opieoils.co.uk/showproduct.a ... ission-oil&" onclick="window.open(this.href);return false;
Think they will be good enough and correct grades etc?
Also wondering what sizes the diff and gearbox washers are, as I think just changing those is enough instead of new bolts.
Never, Never, Never Give Up. Sir Winston
135I Convertible Yas Marina Blue, 1M Conversion MHD stage 1+ Fmic, 3" chargepipe + hks bov, custom downpipes and horse power freaks cat-back, bms dual intakes, F1 Rep Alloys.
TBC
bcraig1988
Post by bcraig1988 » Thu Feb 25, 2016 8:49 pm
What oil do people recommend for a 2006 130i? Opie are recommending the castrol but alot of people are saying redline on here. Not sure what I should go for
0l0dom0l0
Post by 0l0dom0l0 » Sun Feb 28, 2016 7:49 pm
bcraig1988 wrote:What oil do people recommend for a 2006 130i? Opie are recommending the castrol but alot of people are saying redline on here. Not sure what I should go for
I went for redline and I'm pleased with the results still 7-8k later.
I think next time I will try the oem oil and see what the difference is like.
B12 KIT with M3 LCA and TS.
rusty13
Post by rusty13 » Mon Feb 29, 2016 7:33 am
Anyone done this on an m135i? What's the recommended frequency of changing it?
M135i Estoril Blue - 5 Door - Manual
Post by marco_polo » Mon Feb 29, 2016 8:15 am
rusty13 wrote:Anyone done this on an m135i? What's the recommended frequency of changing it?
Man-box with standard power? Every 50k should be fine.
OManger
Post by OManger » Thu Apr 28, 2016 3:44 pm
In regards to the OEM oil, does anyone know the spec of it?
I know its a GL-3 but what is the (??W??)
09 118D M Sport, 3dr, Man, Full Leathers, 18in Alloys, Sat Nav, Prof Stereo, CC
Post by marco_polo » Thu Apr 28, 2016 3:46 pm
OManger wrote:In regards to the OEM oil, does anyone know the spec of it?
75w80 GL4
OManger
Post by OManger » Thu Apr 28, 2016 3:49 pm
Cheers! How come the recommended oil from BMW is MTF LT3 then?
floydroid
Post by floydroid » Mon Jul 25, 2016 12:22 pm
FirBim wrote: Yes, it does. Did mine tonight, following Marco's excellent how-to. I realised (after refitting everything and lowering the car) that I had overfilled. Two 950ml bottles of Redline MTL is 1900ml, so I should've had about 300ml left in one bottle. There wasn't that much, maybe 100-150mls.
I did mine on the weekend. The car was on ramps on the front and axle stands at the rear - it looked level but wasn't, being tilted down at the rear. This meant I could get more oil in the gearbox than required. If you overfill you can create more drag and maybe foaming issues, so I got the car level and the same happened as in the above quote. It was the diff that showed me it wasn't level - as I undid the diff plug the oil came out...
The existing diff oil wasn't too bad and still yellow. The gearbox oil was black and free flowing. Car has done 100k+ so maybe the diff oil has had a change at some point or it doesn't get too bad.
Return to “How To's”
