Swapping ES model non MF steering wheel with MFSW?????
BeemerBoi
Post by BeemerBoi » Tue Nov 01, 2011 4:49 pm
hi i got a '08' 118d ES e87 , I'm sure this has been asked a million times, can i replace my boring ES model blank steering wheel with Multi Functional steering wheel?? i just want the buttons to work with my Business CD Head unit and i don't want to fit Cruise control or anything like. just a simple swap with my blank steering wheel with MF steering Wheel.
i done my research but im not getting a straight forward answer and im just confused if this is even possible?
so can anyone please help me with this ??
i took the airbag off the steering wheel and took some pictures of what it looks like.
First of all this is my steering wheel
Connection Behind the Airbag
Connection on the Steering Wheel
I hope these pictures helped to get an idea of what it looks like..
so is it possible to swap my non MF steering Wheel with MF Steering Wheel?
Re: Swapping ES model non MF steering wheel with MFSW?????
Post by marco_polo » Tue Nov 01, 2011 5:00 pm
Yes, it's possible.
You'll need the slip rings from a car with a similar car to your own, the MFS wheel and the MFS airbag.
Or you could add the performance wheel? http://www.babybmw.net/howtos/how_to_in ... gWheel.pdf
BeemerBoi
Post by BeemerBoi » Tue Nov 01, 2011 5:06 pm
thanks for the reply,
so i need to get slip rings from a ES model or any 08 model??
and will this be a straight fit without any re-coding??
Post by marco_polo » Tue Nov 01, 2011 5:22 pm
It will need re-coding too.
Not 100% on the slip rings, someone will be able to help.
Think 'Rob-the-Viking' did his, maybe drop him a PM?
Lippo
Post by Lippo » Tue Nov 01, 2011 5:22 pm
IIRC you will need to replace your slip ring with one that has the connections for a MFSW and you will need some coding.
Rob The Viking did this and also a how-to on this subject.
120d SE Coupe, Sparkling Graphite Grey. Added BMW Bluetooth, Full Leather Interior, Cruise Control, 261M's, Digital Speedo & Depo LED DRL's
My Ride
Lippo
Post by Lippo » Tue Nov 01, 2011 5:23 pm
Great minds think alike!
My Ride
BeemerBoi
Post by BeemerBoi » Tue Nov 01, 2011 5:39 pm
Thanks for the help,
it looks too complicated and too much hassle so i'm just gonna let it go :cry:
cheers
Return to “How To's”
