Kidney Grille Replacement.
BigC
Post by BigC » Sat Mar 02, 2013 4:30 pm
Here follows a "step by step" guide to replacing your front grilles on a BMW 1 series.
(My car is a 2006 E87 116i ES but the principal of remove and refit remains the same throughout).
Personally I wanted to change my stock grilles (silver/black) for BMW Gloss Black.
Please Note:-...There are two types of BMW Performance Black Grilles, each with different part numbers. (type A or Type B
The easiest method of identifying which parts you need are to have a look at yours and decide if you need the set with the pointed top corners or the rounded versions (see image below) Mine were of the pointed ilk....but the fitments are just the same.
Identification chart for BMWP Gloss Black Grilles
First of all you need to ensure that you have obtained the proper shape kidney grilles for your particular year and model. (more on this later).
Once you've ascertained you have the correct grilles you need to "pop" the bonnet open....
The two tools you will need for this job are:-
30x Torx Screwdriver
Flat Head Screwdriver.
These are all the tools you'll need.
With the bonnet now open you will notice the rubber bonnet seal running along the lip of the front bumper
You will notice three torx screws above each of the grilles (6 in all) three on the left and three on the right.
In this image you will see that I have removed two of the three screws from the left side.
When you have released all of the screws then you need to unhook the top of the front bumper from the little alignment spur.(below)
Alignment spur
The front bumper should now be pretty loose...loose enough anyway to allow us to access and release the grille clips in order to successfully remove our grilles.
PULL THE FRONT BUMPER UP AND FORWARD. It will withstand a little force (so dont be afraid)
Start on one grille at a time working from the outside top clip first
If you have performed the above correctly and holding the bumper out you will be able to see the grille clip.
Using your Flat Head Screwdriver....push the centre spigot down to release...the first clip should now have been undone and the grill will have loosened slightly....There is one more clip on the top and it can be accessed in the same manner as before albeit a little tighter to get at....This time locate the clip and insert your Flat Head Screwdriver as before whilst pulling slightly away from the car on the grille itself.......The top section should now be free.
There are two more of the same clips to unfasten underneath each grille.
This is a picture from above the left grille compartment....notice beside the left most torx screw (removed) there is a pocket in which you can get your hand down to feel the first of the bottom clips. This is done by touch alone, but it is quite a simple task....
Once you have located the clip with your hand and whilst pulling on the front grille press the clip upward and it will release....."Three down one to go"...........
There is no point trying to stick your arm down and round in there in a vain attempt to reach the fourth and final clip....unless you want to end up like this...lol
Result of a stupid attempt of trying to release that fourth elusive clip :lol:
Anyhow lesson learnt.
It is much simpler just to lift the grille whilst pulling it away from the car in an upward fashion....it will release and more importantly it will not break anything
Old stock grilles removed
Simple enough task with a little patience
One thing you will notice, especially if the grilles have been in for any length of time, is that there will be a build up of grime inside the sills...now's the time to give this a good clean before you fit your new parts.
Amazing amount of road grime built up inside the sills
Fitting the new grilles are simplicity itself
Line up you new kidney grille in its appropriate socket offering the bottom clips towards their seating slot in the bumper.
Offer the bottom clips of the new grille to the slots in the bumper
Then its just a matter of pushing them in until you hear the clips click into place....Once in, give them a gentle tug to see that they have seated correctly and are not loose.
Make sure your rubber bonnet seal is correctly seated with no kinks, insert you bumper back into the alignment spur and check that all the torx screw holes line up....then simply insert and tighten all your screws in sequence and drop the hood.
JOB DONE!
Thank you for taking the time to look through this little walk-through...Hopefully it will come in handy for someone wishing to perform the same task.
Regards
C
midlifecrisis
Re: Kidney Grille Replacement.
Post by midlifecrisis » Sat Mar 02, 2013 5:20 pm
Informative and helpful post for those unsure of how to attempt this - nice one. :thumbs:
Paul
2010 123d M Sport Space Grey
2012 M135i Mineral Grey (Mustafa Mk I)
2014 M135i Sapphire Black (Mustafa Mk II)
2016 M140i Mineral Grey (Mustafa Mk III)
bobbydm
Post by bobbydm » Wed Apr 17, 2013 9:32 pm
NIce write up with good pics. Tempted to have a go at mine!
B_Wood
Post by B_Wood » Tue Apr 23, 2013 6:49 pm
Re: the 30x torx screwdriver, what mm do I need to get? Thanks
116i ///M Sport Le Mans Blue - 208M's | Pro HU | Facelift Rear lights | Silver Indicator bulbs | Stubby Aerial
Post by marco_polo » Tue Apr 23, 2013 6:55 pm
It's a T30, no?
Sanj
Post by Sanj » Wed May 22, 2013 8:36 pm
Great post (wish I'd seen it before I did mine) - I managed to get my arm in to get to that inner middle lower clip. Yes I did the same to my arm too. Thought I'd share my results of the same finish - gloss black but on a black car. Now matches the rear darkline look. :)
Only difference - I bought some OEM grills off eBay, painted them myself.
Grills
And some before and after shots for you.
Granted colour of the car has a lot to do with it, don't think I would have done this if the car wasn't black.
BigC
Post by BigC » Thu May 23, 2013 5:37 pm
Makes all the difference....nice car mate....just love BLACK.
Nice front end
Thanks for posting
Regards
C
goebes
Post by goebes » Thu Sep 12, 2013 12:49 pm
Just swapped my "chrome" grills with the black ones using this guide, times like this it would have been handy having tiny hands because those lower clips are a right pain in d ass and I've got the blood to prove it!
Thanks for posting it :)
2013 F21 Glacier White M135i
robbooth
Post by robbooth » Sun Sep 22, 2013 9:54 pm
Great write-up, a nice, subtle change, I think I'll have to do this myself!
WP-UK
Post by WP-UK » Sun Nov 10, 2013 12:02 pm
Thanks for this guide, my grills have arrived so going to attempt this today.
Will
BMW 116i M Sport '08 (58) | Titanium Silver | 208M Alloys | Goodyear Eagle F1 Tyres | Comfort Pack | LED Upgrades | Darklines | BMWP Black Grilles | 130i back box
Quikrex
Post by Quikrex » Tue Dec 10, 2013 3:52 pm
thanks for this trying to get my hands on some bmwp ones now :)
2006 Le Mans Blue 130i M Sport, bmw performance strut
Past: 2003 Blob eye Subaru WRX 260HP 295Nm
Yellacoffee1
Post by Yellacoffee1 » Mon Jan 20, 2014 9:47 am
Nice write up cheers, shall be attempting this soon.
R0nin
Post by R0nin » Fri Feb 28, 2014 9:34 am
Many thanks to OP - did this yesterday, took all of 10 minutes :thumbs:
Quikrex
Post by Quikrex » Sat Mar 01, 2014 12:53 pm
Hmmmm has anyone got something that works on the 130 as there is no space in there to do anything!?
Quikrex
Post by Quikrex » Sat Mar 01, 2014 11:01 pm
Just found a post where Marco mentions sliding something between the bumper and the grill... That scares me lol hopefully I can try that in the morning!
Return to “How To's”
