Egr Restrictor how to
timk
Re: Egr Restrictor how to
Post by timk » Sun May 04, 2014 10:35 am
I attempted this today, but a 22mm Welch plug is too small:
I think a 24mm one would work well, but I'll report back!
damianz
Post by damianz » Sat Jul 05, 2014 4:34 pm
Also have this plate but finally decided to get rid off it and you can disable (not completely) EGR through DIS software. Job for 5mins and clean job.
Makes me happy :D
jason@bwchiptune
Post by jason@bwchiptune » Mon Sep 25, 2017 8:43 pm
The best way to keep the egr closed
is to set it to closed all the time in the ecus software when doing a remap
If this is done the correct way the dpf will still regen on cars fitted with a dpf system
BW chiptune
Tuning BMWs since 1991
Dyno Dynamics rolling road
BW autorepairs
Over 30 year repairing BMWs
New and fully refurbished BMW Ecus and Cas units
BMW Keys made and cut same day
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used)
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars
DPF repairs fixed without the need of removal
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Bimmer112
Post by Bimmer112 » Mon Jul 30, 2018 3:52 pm
Want to do this mod tomorrow , just nos sure if i need flat 22mm cap - this one: (https://www.ebay.co.uk/itm/Female-Pipe- ... 2CbS5aFWbg)
or the one with solder ring - https://www.ebay.co.uk/itm/Stop-End-Cap ... kjanWlbGVA
BMW e87 118d M47N2
K+DCAN coding (NCS Expert , INPA ,Tool32...)
Post by marco_polo » Mon Jul 30, 2018 4:28 pm
Most people use a solder ring version. I think either would be ok though, that hole in the side of the ERG Body is tapered.
jason@bwchiptune
Post by jason@bwchiptune » Tue Aug 07, 2018 3:24 am
We can program the dde so the the egr will stay closed all the time
This will keep the intake manifold clean and reduce the wear on the swirflaps
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
Return to “How To's”
