How To Install Double Din Head Unit (E8x) Alpine ILX-700
SupernoodlesRS
Post by SupernoodlesRS » Mon May 29, 2017 6:17 pm
Hey Guys,
I personally installed an Alpine ILX-700 as I wanted Apple Car Play - In my opinion I think this is a much easier and cost effective method then installing iDrive which was an option I looked at originally.
I couldn't find a guide anywhere on installing a double din head unit and so as I have done this I have just typed one up and the link is here:https://www.mediafire.com/?uo9zn4lvf20g2kd
My car ended up like this as a finished result which I was quite pleased with:
I have taken a lot of advice from this forum and have successfully installed and coded cruise control into my car as a result I felt it was important to give a guide back so I hope this helps some of you members out!
Feel free to comment or PM me any queries!
Giggs
Re: How To Install Double Din Head Unit (E8x) Alpine ILX-700
Post by Giggs » Mon May 29, 2017 9:43 pm
Looks great, I skimmed over the guide and it looks very professional, good job man I bet loads of people will do this now with help of your guide.
2008 E87 116i N43 - Some Mods
SupernoodlesRS
Post by SupernoodlesRS » Mon May 29, 2017 10:43 pm
Thanks :) hopefully it will help a few people out!
drassini
Post by drassini » Sat Jul 08, 2017 10:09 am
that's pretty much exactly what I am about to do. Did you use a kit to retain the pdc noise etc or did you buy a full fitting kit? if so which one can you remember? Lastly did you instal a reverse camera? I was planning on doing that while I was changing stereo too. (mine is a 2010 e82 if that matters)
SupernoodlesRS
Post by SupernoodlesRS » Sun Jul 16, 2017 9:06 am
Hi Mate!
Okay so I managed to keep the PDC noise, this is part of the wiring kit that I bought - however it comes out of a separate speaker and is a lot quieter than the standard noise which comes out the cars speakers. I personally didn't fit a reversing camera but it wouldn't be hard - the alpine unit I have has a wire on its loom for a feed into it so if you wanted to add this it would be pretty simple!
Good luck bud!
Bilse84
Post by Bilse84 » Fri Apr 27, 2018 12:12 am
Good guide man! I recently fitted an alpine ine-w987d in my e82 with the aid of it.
I also had hardly any sound coming the speaker for the warning sounds etc and when I checked it out noticed there was another socket on the speaker, swapped into that one and got way better volume.
Return to “How To's”
