Heater fan not working
whodareswins1
Post by whodareswins1 » Fri Sep 14, 2018 3:17 pm
I took my heater fan out to investigate an issue where at higher speeds it makes the dash vibrate a fair amount. It's quite noisy. Turns it the likely culprit was a snail shell inside.
I've replaced it all back but now the fan doesn't appear to turn on. I've tried unplugging it and plugging back in. Sounds like a small hum near the motor when it is plugged in. Any idea what could be the issue?
whodareswins1
Re: Heater fan not working
Post by whodareswins1 » Fri Sep 14, 2018 4:01 pm
Update...
I had the fan plugged in but not bolted in and it worked perfectly. Tried different fan speeds too and it worked fine. It's when I bolt it back in to place, it doesn't appear to function.
What am I doing wrong?
F20 116i
Post by marco_polo » Fri Sep 14, 2018 4:28 pm
Are you stressing it when you bolt it down? IE, physically warping it's shape with the wrong blower position, or incorrect bolts/torques?
whodareswins1
Post by whodareswins1 » Fri Sep 14, 2018 4:32 pm
Hmm. I have tightened them up fair bit. Do they not need to be too tight?
F20 116i
Post by marco_polo » Fri Sep 14, 2018 4:38 pm
They need to be exactly the same as they were before.
whodareswins1
Post by whodareswins1 » Fri Sep 14, 2018 5:20 pm
Thought so. It turned it wasn't quite seated correctly. It looked and felt fine but as I loosened the bolts a bit it seated properly and all is now well. Thanks for the help
F20 116i
