Squeaky steering wheel
Boombap
Post by Boombap » Wed Nov 08, 2017 6:47 pm
Occasionally noticing a squeaking directly from behind the steering wheel, this has only developed recently and oddly only occurs when turning from right to center.
A clip of the culprit:
https://1drv.ms/u/s!AmoZbHD48InOm2FP-OoFVKAKbssN
Would this indicate an issue with the belt or pump?
2006 130i manual :)
teasdas
Re: Squeaky steering wheel
Post by teasdas » Thu Nov 09, 2017 12:50 am
Boombap wrote:Occasionally noticing a squeaking directly from behind the steering wheel, this has only developed recently and oddly only occurs when turning from right to center.
Can’t watch the video but I had a similar issue. The steering column passes through a rubber grommet in the bulkhead/firewall. Spray a load of silicone grease around there and turn the wheel back and forth. Mine hasn’t been back since
MontegoBlue
Post by MontegoBlue » Thu Nov 09, 2017 11:35 am
Have you tried re-adjusting your steering rake/position, my E91 squeaks, changed the rake etc, and its gone.
Current - 2012 318d N47 Touring - 94,000 miles
Current - 1966 1300 Beetle - 168,000 miles
Past - 2008 118d N47 - last seen 180,000 miles
Past - 2005 Toyota Avensis - last seen 156,000 miles
Past - 2003 Renault Clio - last seen 134,000 miles
Boombap
Post by Boombap » Thu Nov 09, 2017 2:29 pm
Why did I not think of that.. seems to have sorted the issue (for good hopefully)
Will report back if it re-occurs
2006 130i manual :)
Return to “BMW Problems”
