F20 116i flat and hesitant
GarryK
Post by GarryK » Mon Jan 22, 2018 9:14 pm
Evening
116i when cold can be a pain. Sure it misfires occasionally and when I set off and go from first to second the acceleration is smooth then stops and then picks up again.
Like the pedal is depressed and pressed again
Also I’m sure when you’re on light throttle. Say 30mph in 4th you can feel it misfire and being hesistant.
I’ve not had any warnings on the dash.
I don’t have Carly or similar.
So any common faults that could be pointed out?
Plugs etc done 12 months ago and covered about 6000 miles.
2012 F20 mineral grey 116i Msport
Return to “BMW Problems”
