DPF Issue 00452A??
ttassie15
DPF Issue 00452A??
Post by ttassie15 » Mon Apr 16, 2018 6:28 pm
Hi guys,
Run a diagnostic on Carly app and get fault code 00452a, which from what I’ve read means the dpf is on deaths door? Is this actually the case and it needs replacing or can I get it cleaned out? The car doesn’t seem to regen because of the issue on the dpf (madness). It’s on 56g ash and 49g soot. Tried constantly to clear the fault whilst driving along but with no luck. Don’t really want to dpf delete due to resale and mot issues.
123D M Sport E82
Re: DPF Issue 00452A??
Post by marco_polo » Mon Apr 16, 2018 6:32 pm
Remove it and backflush to remove the incombustible ash?
ttassie15
Post by ttassie15 » Mon Apr 16, 2018 8:20 pm
marco_polo wrote:Remove it and backflush to remove the incombustible ash?
Is removing the dpf easy enough, there’s a garage in Essex that offer a cleaning service so basically the same thing? And unsure whether or not that’ll sort the fault code?
123D M Sport E82
Post by marco_polo » Mon Apr 16, 2018 8:34 pm
If it's definitely knackered due to being full of ash (and not just exhaust soot), I'd remove it and have a go with a low powered jetwash or a hose. It's got to come off anyway if it needs replacing, what have you got to lose?
Soot is black; ash tends to be much lighter in colour (beige/orange colour). I'd wash it out until the water runs clear, dry it thoroughly and refit.
ttassie15
Post by ttassie15 » Mon Apr 16, 2018 8:50 pm
Cheers, I’ll give that a go! Is removing the dpf something joe bloggs can do?
123D M Sport E82
Post by marco_polo » Mon Apr 16, 2018 9:31 pm
Yeah, piece of p*ss.
I'd probably want (at least) a new seal + nut and bolt to go on the screw clamp though, they tend to rust with the heat.
http://www.realoem.com/bmw/enUS/showpar ... Id=18_0731
ttassie15
Post by ttassie15 » Tue Apr 17, 2018 5:28 am
New bits ordered, hopefully sort it this weekend
123D M Sport E82
jason@bwchiptune
Post by jason@bwchiptune » Wed Apr 18, 2018 2:29 am
There is no point and it's a waste of time cleaning the dpf
I've proven that a bmw dpf will last 350,000 miles
If the dpf is blocking up its due to a problem on the engine or with the car
You do not need to change the dpf every unless it melted
Even if it's fully blocked I've been able to regen the dpf after fixing the problems that are giving the ecu the wrong info
BW chiptune
Tuning BMWs since 1991.
Dyno Dynamics rolling road.
BW autorepairs
Over 30 year repairing BMWs.
New and fully refurbished BMW/Alpina ,Ecus (DME,DDE) and Cas units.
BMW Ecu repairs.
BMW FRM repairs.
BMW remote Keys made and cut same day with or without car even if all keys lost we can supply you a key like the dealers do.
BMW key blades cut from BMW key code.
Key data fixed for non starters or when theft attempted by making key by obd.
Correction of Engine ECUs Cas and key fitted to your car (when a key set from a different car has been used).
Digital Service Records rest and corrections in idrive screen on 2013 onwards cars.
DPF repairs fixed without the need of removal of its guts or replacement.
40% of my work is repairing the problems that are caused by other tuners remap
For more info look in our section under sponsors on this forum
0208 561 1818
07831 103030
Hayes
UB3 1BB
Click here for: BMW Remaps
Click here for: BMW Repairs
DynoDynamics rolling road testing in london & newcastle
dealers across the uk
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
ttassie15
Post by ttassie15 » Sun Apr 22, 2018 8:08 pm
Took the car for another long drive on the motorway today with the new turbos fitted. Managed to get a regen and down to 5g of soot. Fault code is still there though?
123D M Sport E82
Post by marco_polo » Mon Apr 23, 2018 9:00 am
How much ash?
ttassie15
Post by ttassie15 » Mon Apr 23, 2018 11:16 am
About 54g, so is that about half full? Think Carly says about 100g is when it’s due to be replaced, if that’s anything to go off
123D M Sport E82
jason@bwchiptune
Post by jason@bwchiptune » Sat Apr 28, 2018 10:09 pm
I've never needed to replace a dpf as I've proven these to last over 350,000 miles
Unless it's melted by someone driving down the motorway at 4,000rpm in a lower gear for 1hour which we saw the other day
BW chiptune
BW autorepairs
BMW Ecu repairs.
BMW FRM repairs.
0208 561 1818
07831 103030
Hayes
UB3 1BB
BMW tech
Performance tuning
Ecu repairs
8 & 9 Alpha ind est
Hayes
Ub3 1bb
02085611818
07831103030
ttassie15
Post by ttassie15 » Fri May 04, 2018 5:31 pm
Had the dpf professionally cleaned by quite a well known garage, and Carly is still reading a fault code on it, and the soot and ash levels are exactly the same as before the clean?
Are there any sensors that could’ve failed? Or have I been taken for a ride?
123D M Sport E82
Return to “BMW Problems”
