Problems possibly terminal....
Dominic H
Post by Dominic H » Wed Jun 27, 2018 5:02 pm
Afternoon all,
I have a 2007 120d auto with 91000 miles showing. It was an AUC car 3 years ago and is BMW main dealer maintained.
At the weekend my wife was driving at 70mph on the motorway, when there was a sudden loss of power. She was able to make progress home at around 40-50 mph, as she was only 10 miles from home. Once home, I examined the car to find that it started, idled and reved in neutral seemingly correctly. I drove it around the bloke, it was fine up to about 20mph, any faster and there is a noticeable sharp/shrill noise.
The car is under the BMW driveline warranty so I took it to the local BMW main dealer on Monday morning. They have just called back to say that it's not looking good. They have read the OBC and a number of faults are showing;
Fault on EGR
Fault on DPF
Fault on inlet manifold
Fault on glowplugs
Fault requiring software update
An itemised estimate estimate is being prepared, but as a guide it was indicated that the parts would be over £2000 plus labour plus vat.
Bearing in mind it is worth £3000 on a good day, the cost of the repairs are going to be more than the car. Are these faults repairable at a sensible budget, or is an otherwise sound car just good for scrapping?
The forum helped me reduce an estimate of circa £3000 to replace a worn ABS pump to around £600 last year so any advice is appreciated.
Dominic
HaiderGill
Re: Problems possibly terminal....
Post by HaiderGill » Wed Jun 27, 2018 7:20 pm
You want to find out what parts need changing and why?
Then we can probably help you further. I have 55 plate 120d on a 130k miles and that does seem an expensive repair bill.
Dominic H
Post by Dominic H » Wed Jun 27, 2018 8:00 pm
Thanks Haider,
The service department is preparing a decent sized estimate which itemise the parts required, and should give the fault codes. I should have this in the morning.
Thanks for feedback.. D
barneyrubble
Post by barneyrubble » Wed Jun 27, 2018 9:14 pm
I think the warranty only covers you to the value of the car if I remember correctly.
Not sure what they do at that point - do they give you the cash and scrap the car?
If it's got breasts or wheels - it's going to give you trouble
Black Sapphire Metallic M2 LCI
Dominic H
Post by Dominic H » Sat Jun 30, 2018 10:51 am
Right, I have the estimate from BMW. There are three areas that are showing permanent fault codes;
DPF at £1485 plus vat inc bits and labour.
Glow plugs/pre-heater at £555.05 plus vat inc bits and labour.
Fuel heater £829.52 plus vat inc labour.
A total of £3444.58 inc vat and parts.
It was explained that the inlet manifold was also showing faults and was likely to be blocked. There is a strong likelihood of additional costs once they'd started the work.
I guess the next move would be to see if any of these issues/parts can be repaired rather than replaced at an Indy. See what the non-franchised cost would be. Then take a decision as to whether its worth doing. As per the OP, it seems a shame for an otherwise well maintained, reliable car....
stevesurrey
Post by stevesurrey » Sat Jun 30, 2018 11:19 am
How much of that bill will be covered by your warranty?
Return to “BMW Problems”
