New Owner Old Problems - 123d
RobMorris
Post by RobMorris » Thu Aug 16, 2018 4:24 pm
Hi all
New Owner here of a 2008 123d with existing problems.
I bought it as spares/repairs. I'm not a qualified mechanic but handy with a spanner and I can use Google/Forums/YouTube etc.
Anyway my 'new' car has absolutely now power; it feels like it has only 50bhp - I am assuming (hoping) it is in Limp Mode. Otherwise its driving alright.
The DTC light is on constant amber and believe its this fact that is resulting in the Limp Mode?
I plugged in my eBay reader and it says there are no faults to read?
So now I am gathering intel of where to start first.
1. Could be ABS sensor / Reluctor ring / Driveshaft fault
2. ABS Pump fault
3. DSC Control Unit fault
Anything else I can check?
Thanks Rob
Re: New Owner Old Problems - 123d
Post by marco_polo » Thu Aug 16, 2018 4:31 pm
I'd check the 3 turbo actuators (8, 9 & 10) for starters:
Air filter and fuel filter are worth crossing off your check-list too.
No funny noises? Boost leaks? EGR and DPF clean and clear?
RobMorris
Post by RobMorris » Fri Aug 17, 2018 10:22 am
Thank you
I shall add these to the list.
RobMorris
Post by RobMorris » Sat Aug 18, 2018 8:38 am
Using the onboard diagnostics through the stalk - I am receiving the following CCID codes
24
35
71
Investigation continues
Post by marco_polo » Sat Aug 18, 2018 8:57 am
71 is just the rear brake wear sensor, iirc. Replace and reset, and it should clear.
RobMorris
Post by RobMorris » Sat Aug 18, 2018 11:47 am
Thank you sir - The rear pads and discs were only replaced 2 months ago and on inspection today still look brand new. Perhaps it just needs a reset or the wear sensor was not replaced at the same time / faulty.
Further fault finding / check list
Additional to the permanant DSC light on (Amber) (Sorry not the DTC light as I mentioned at first)
I also noticed the handbrake light is on permanant (Red) - Even when driving / Handbrake off.
I checked the brake fluid level and reads MAX.
I have then removed the rear wheels and checked the ABS/Speed sensors. Both sides look good but I do have a question..
Should all cars (Incl my 2008 E81 123d) have reluctor rings on the drive shafts?
With sensors out - I can look through to the shaft but I see no relector ring 'teeth'. I see just a rusty 'smoothish' shaft as I turn the wheel.
Could both sides have corroded so much they have perished?
Regards Rob
Post by marco_polo » Sat Aug 18, 2018 11:54 am
The brake warning light could just be the rear wear sensor. What does the mileage say on the rear brake CBS? --.-- ?
Not all reluctors are the same design, the better ones are built into the rear wheel bearings.
mikesmith2939
Post by mikesmith2939 » Sat Aug 18, 2018 12:03 pm
It may be worth investing in a BMW specific code reader rather than a generic one as some are not able to read all the modules.
RobMorris
Post by RobMorris » Sat Aug 18, 2018 12:35 pm
Ive bit the bullet and have a 'proper mechanic' (mobile) on his way with a real diagnostics machine. My cheapy eBay rig found nothing so fingers crossed.
RobMorris
Post by RobMorris » Sat Aug 18, 2018 2:49 pm
The real codes -
4C12 - Message: (STAT_DSC, 0x19E), signals in message not valid
4A74 - Glow system, communication
4A79 - Glow system, communication
5E24 - Hydraulic unit, pressure sensor; plausibility
5E20 - Hydraulic unit, pressure sensor, internal fault
5DE1 - Brake pad wear, plausibility, rear axle
Post by marco_polo » Sat Aug 18, 2018 3:45 pm
Steering angle sensor, glow plug issue, DSC Hydro unit sensor, and a rear brake sensor.
None of that should cause a 50bhp Limp mode though.
RobMorris
Post by RobMorris » Sun Aug 19, 2018 3:00 pm
Thanks @marco_polo
Can I assume code 4C12 refers to the steering angle sensor?
Post by marco_polo » Sun Aug 19, 2018 3:06 pm
I suspect so, hopefully it just needs recalibrating. Is your battery healthy and fully charged? If not, that can cause electrical gremlins including SAS issues.
RobMorris
Post by RobMorris » Sun Aug 19, 2018 4:46 pm
Battery is good. Stop/start works which I think is a good indication.
I believe the calibration is turning the steering wheel full lock left to right over and over? I have done this but nothing has changed with the dash lights and I cant keep calling out the 'Diagnostics man' at £50 a time to check.
I have bought the following and hopefully I can do it myself? - https://www.ebay.co.uk/itm/BMW-USB-OBD- ... 2749.l2649
Post by marco_polo » Sun Aug 19, 2018 4:59 pm
I don't know of anyone who's successfully reset their SAS with the DIY Left/Right procedure.
Return to “BMW Problems”
