Flexi Exhaust Issue
mkzp
Flexi Exhaust Issue
Post by mkzp » Thu Oct 18, 2018 4:19 pm
Hi guys
I have a bmw 1 series 118d m Sport (2008) where the flex has gone on the exhaust. I have been advised that i can get a exhaust flex reapir kit via ebay etc and get it welded by my local garage as the exhaust place are saying that they will only sell the whole unit which includes dpf. I have enquired at a few places via ebay with regards to purchasing the product below however i got a response below from the seller which has got me worried as i do not want to purchase a part which will not work - Any ideas where i can purchase the correct item from or if the item below is suffice ? Thanking everyone in advance for any assistance
https://www.ebay.co.uk/itm/111104740289?ul_noapp=true
"Thank you for your message
Unfortunately we are not sure if these are suitable for the M Sport Models, We have had customers in the past who struggled to fit without tweaking and welding, Others it fitted perfectly so we cannot be sure
We have not had the M Sports exhaust here to check, We have only based this on the standard exhaust
I can send you the dimensions of this if you wish to check against your current exhaust?
The short slotted end is made to go over end of DPF pipe once old flex has been removed and " Lip" of tube been smoothed down
The angled end is made to fit inside the centre pipe
Kind Regards
Gemma"
Re: Flexi Exhaust Issue
Post by marco_polo » Thu Oct 18, 2018 5:06 pm
M Sport exhausts (and engines, gearboxes, differentials, brakes, etc) are exactly the same as stock/SE models, zero difference.
If they don't want your money, ring around a few local exhaust fabricators.
Return to “BMW Problems”
