Top up washes question
Moderators: Lambster, Rich196, Producethis, marco_polo, babybmwadmin
Justchris17
Post by Justchris17 »
I recently spent over 4 hours last week cleaning, decontaminating, polishing and waxing my car. To give the car a top wash and top up of polish and wax would I need to do the whole process again?
I know I could simply snow foam, wash and dry but would that not wash away the wax and polish?
2010 N55 135i, Manual, Metallic sapphire black, Coral red leather
2009 Mazda6 TS2 Estate for the dog/tip
Justchris17
Re: Top up washes question
I don’t know if it matters but I used BH cleanser polish and BH finis wax
RBS Bob
Post by RBS Bob »
As long as you use PH neutral Snow Foam and car wash then your LSP, Last Stage Protection, should last a while.
Can always top up with a Quick Detailer spray after each wash.
2015 135i F20 Auto Alpine White Red Leather. 1992 1.9 Peugeot 205 GTI. KTM Duke 2 640.
Justchris17
I am using bilt hamber I’ve got the auto foam and auto wash will these be ok?
Quick detailed spray I’m going to look into that thanks
nivens
Post by nivens »
Wax should hold up well for a few months unless you use a really strong shampoo\foam mix that starts to break it down. If you've done all the hard work previously you can usually get away with giving it a quick wax every month or two or use a quick detailer after every wash and make the full decontamination wash an annual thing.
2005 E87 130i - Bilstein B12 Pro Kit
RBS Bob
Post by RBS Bob »
Justchris17 wrote: Wed Apr 07, 2021 1:11 pm I am using bilt hamber I’ve got the auto foam and auto wash will these be ok?
Bilt Hamber will be fine.
You will not go wrong with
https://www.eurocarparts.com/p/sonax-xt ... rWEALw_wcB as a Detailing Spray.
pje16
Post by pje16 »
RBS Bob wrote: Wed Apr 07, 2021 2:42 pm You will not go wrong with
I can back this up
use it after every wash and the beading effect when it rains looks great
2018 BMW F22 220d
Ex 2004 E46 BMW320d
Nyxeris
Post by Nyxeris »
Make sure you're diluting the Auto-Foam correctly, it's a bit of a faff to calculate your dilution rate but once you've done it you're sorted forever. I use it at about 1.5% strength and it works perfectly.
Likewise with Auto-Wash - it's massively concentrated so 5ml (1 teaspoon) is all you need in your wash bucket. Don't be tempted to use more than you need!
E81 130i | Build Thread
Click here for BabyBMW stickers!
nickfrog
Post by nickfrog »
Justchris17 wrote: Wed Apr 07, 2021 1:00 pm To give the car a top wash and top up of polish and wax would I need to do the whole process again?
If you polish it again you'll remove any protection you've previously applied. Most waxes won't last very long, consider a sealant instead, even a cheap one.
Current
M2 2017 manual
Previous
Megane RS 280 Cup
Megane RS Cup-S 275
M135i LCI 3-dr, manual
Toyota GT86
E82 125i on 130i power+brakes
