Wheel Balancing Adhesive Removal
2Stevo2
Post by 2Stevo2 » Tue Dec 19, 2017 1:16 pm
Chaps,
I am trying to get rid of the black wheel balancing foam/adhesive left behind on the rims when the wheels are re-balanced. Does anyone know of any tools or tips to remove it?
It can be seen at the top right of this picture I took a while ago...
F20 120d M-Sport Auto plus extras
Barney McGrew
Re: Wheel Balancing Adhesive Removal
Post by Barney McGrew » Tue Dec 19, 2017 1:19 pm
WD40.
Works on things like that really well. Obviously don't spray near the brakes/discs.
2Stevo2
Post by 2Stevo2 » Tue Dec 19, 2017 1:25 pm
WD40.
Cool I'll give that a try....
Is there any blunt tools I could use? I have in my head a blunt piece of plastic or something similar might do the job. I feel just using a cloth takes ages!!
Barney McGrew
Post by Barney McGrew » Tue Dec 19, 2017 2:31 pm
If the WD40 works as expected, a tough rag will be fine and will be 'abrasive' enough to work with the WD40 to lift the adhesive off.
This is why it's a good method. Use some elbow grease and no risk to damaging paint etc. You can use plastic scrapers etc but you only need a small piece of sand/grit to lodge under it and it'll mark the surface.
In this weather a hair dryer might help loosen the adhesive too and make things easier.
2Stevo2
Post by 2Stevo2 » Tue Dec 19, 2017 4:17 pm
Post by Blind Pugh » Tue Dec 19, 2017 10:16 pm
Chaps,
Stevo
Try
- WD40 - liquid mechanic
- Acetone / nail varnish remover - "borrow" from SWMBO
- Sticky stuff remover http://www.halfords.com/motoring/car-cl ... ff-remover
Use this on motorbike alloy wheels and it works a treat.
BP
Barney McGrew
Post by Barney McGrew » Wed Dec 20, 2017 9:00 am
- Acetone / nail varnish - "borrow" from SWMBO
I would be careful with acetone, it's a very aggressive solvent and can melt plastics etc if you spill it on them. While it works well at things like this, I'd probably not recommend it just in case it's weakening the top coat etc.
Heard good things about the sticky stuff remover though.
Generally I always recommend WD40 as it's usually something most people have to hand so a good first try.
Post by Blind Pugh » Wed Dec 20, 2017 9:03 am
Barney
Fair point - nail varnish remover is much kinder than Acetone.
BP
2Stevo2
Post by 2Stevo2 » Wed Dec 20, 2017 1:37 pm
Found this plastic razor blade set and it worked an absolute treat!!!.....a bit of WD40, let it sink in, gently scrape off. Job done on all 4 wheels in 10 mins with minimal effort :D
janhe
Post by janhe » Wed Dec 20, 2017 4:34 pm
These are also very good when removing adhesive residues.
https://www.ebay.co.uk/itm/RUBBER-ERASE ... 1360407981
Just be smart and don’t burn the paint. :)
tyusaf
Post by tyusaf » Thu Dec 21, 2017 9:58 am
Cotton wool pads (round ones)
Spray them with Tar Remover
Stick them to the problem areas
Come back 20 mins later, should come clean off
The rubber/caramel wheel is perfect for when the tar remover doesn’t work; difficult to burn paint, what normally happens is that you heat it up by running it too fast, and you leave a rubber stain to remove. Again tar remover will do the job. Just go slow.
