245/45/18 - will they fit??
Moderators: babybmwadmin, Producethis, marco_polo, Rich196, Lambster
ttassie15
Post by ttassie15 » Fri Nov 09, 2018 7:10 am
I’m after a set of winter tyres, and found some fairly cheap ones online. Will they fit on my car? Comparing them online they’re 40mm larger (diameter) than my current ones?
Cheers!
123D M Sport E82
Re: 245/45/18 - will they fit??
Post by marco_polo » Fri Nov 09, 2018 8:43 am
Nope, not with those tractor tyres on.
ttassie15
Post by ttassie15 » Fri Nov 09, 2018 8:51 am
Any size you would recommend?
I was thinking 225/40/18 would be fine for the front, maybe go for the same as the front?
Or 235/40/18?
123D M Sport E82
Post by marco_polo » Fri Nov 09, 2018 9:00 am
225/40/18 front
235/40/18 or 245/35/18 rear. 123d has lots of torque, I wouldn't go too narrow. Maybe consider 255/35/18 rears too, assuming you have 8.5" rears?
ttassie15
Post by ttassie15 » Fri Nov 09, 2018 9:03 am
Yeah 8.5” rears, was just after a cheapish set to get me through the winter. I’ll have a look, cheers!
123D M Sport E82
sladoled
Post by sladoled » Fri Mar 15, 2019 11:20 am
Hello, going from 17" to 18" with my summer tires, similar question - I would like to buy 3 series rims (193m - 8x18 ET34 fron, 8,5x18 ET37 rear), found ones but i'm a little concerned about the tires. Front ones are 225/40, rear ones are 255/35. My concern is related to the cars suspension - are 255 tires a little too wide an also - maybe there will be some rubbing involved? Also, how would 225/40 work on 8,5 rim?
The car is 2009 E87 120D.
Thank you
Post by marco_polo » Fri Mar 15, 2019 11:34 am
Thank you
The fronts would poke and the rears would probably rub.
sladoled
Post by sladoled » Fri Mar 15, 2019 1:39 pm
My current setup is 225/45/17 on 8x17 ET 34 (style 285) rims so I guess the front will be the same, my concern is the rear. Would 225/40 work on the rear with 8,5 rims? If not, what's the best measurement to go with, 235/40 ir mayb 245/35? Thank you
Post by marco_polo » Fri Mar 15, 2019 2:35 pm
Yup, front would be the same, 235/40/18 95 are probably the safest choice for the back.
sladoled
Post by sladoled » Sun Mar 17, 2019 2:52 pm
Thank you, much obliged!
